Ich habe schon div. ähnliche Artikel diesbezüglich gelesen und versucht den Fehler einzugrenzen. Leider ohne Erfolg! Bitte um Hilfe!! Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Syntax Error in template “string:” on line 77 " " unclosed {if} tag in Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php on line 404 Stack trace: #0 Vendor/Smarty/libs/sysplugins/smarty_internal_smartytemplatecompiler.php(64): Smarty_Internal_TemplateCompilerBase->trigger_template_error(‘unclosed {if} t…’) #1 Vendor/Smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php(83): Smarty_Internal_SmartyTemplateCompiler->doCompile(‘Hallo {billing...') #2 Vendor/Smarty/libs/sysplugins/smarty\_internal\_template.php(271): Smarty\_Internal\_TemplateCompilerBase-\>compileTemplate(Object(Enlight\_Template\_Template)) #3 Vendor/Smarty/libs/sysplugins/smarty\_internal\_template.php(426): Smarty\_Internal\_Template-\>compileTemplateSource() #4 Enlight/Template/Template.php(46): Smarty\_Internal\_Template-\>renderTemplate() #5 Vendor/Smarty/libs/sysplugins/smarty\_internal\_template.php(568): Enlight\_Template\_Template-\>renderTemplate() #6 Vendor/Smarty/libs/Smarty.class.php(328): Smarty\_Internal\_Template-\>getRenderedTemplate() #7 engine/core/class/sOrder.php(916): Smarty-\>fetch('string:Hallo {…’) #8 engine/core/class/sOrder.php(813): sOrder->sendMail(Array) #9 Shopware/Controllers/Frontend/Checkout.php(401): sOrder->sSaveOrder() #10 Shopware/Controllers/Frontend/Checkout.php(127): Shopware_Controllers_Frontend_Checkout->saveOrder() #11 Enlight/Controller/Action.php(55): Shopware_Controllers_Frontend_Checkout->finishAction() #12 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‘finishAction’) #13 Enlight/Controller/Front.php(88): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #14 Shopware/Bootstrap.php(21): Enlight_Controller_Front->dispatch() #15 Enlight/Application.php(69): Shopware_Bootstrap->run() #16 shopware.php(6): Enlight_Application->run() #17 {main}
So wie es in der Fehlermeldung steht: [quote]unclosed {if} tag[/quote] Irgendein Template wurde geändert, und in dem wurde der if Tag nicht geschlossen. Schau mal, ob die Bestellbestätigungsmail geändert wurde und irgendwelche Abfragen nicht geschlossen wurden.
