Liebe Community ich verzweifle… Message: exception ‚Enlight_Controller_Exception‘ with message ‚Unauthorized‘ in /www/htdocs/w0133b1f/Shopware/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:202 Stack trace: #0 /www/htdocs/w0133b1f/Shopware/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs)) #1 /www/htdocs/w0133b1f/Shopware/engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs)) #2 /www/htdocs/w0133b1f/Shopware/engine/Library/Enlight/Controller/Action.php(138): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs)) #3 /www/htdocs/w0133b1f/Shopware/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight_Controller_Action->dispatch(‚getLastOrdersAc…‘) #4 /www/htdocs/w0133b1f/Shopware/engine/Library/Enlight/Controller/Front.php(227): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #5 /www/htdocs/w0133b1f/Shopware/engine/Shopware/Kernel.php(143): Enlight_Controller_Front->dispatch() #6 /www/htdocs/w0133b1f/Shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 /www/htdocs/w0133b1f/Shopware/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 /www/htdocs/w0133b1f/Shopware/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(261): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 /www/htdocs/w0133b1f/Shopware/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 /www/htdocs/w0133b1f/Shopware/shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main} Time: 2015-06-12T17:07:30.278980+0200 Channel: core request: { „uri“: „/backend/widgets/getVisitors?_dc=1434121650378&page=1&start=0&limit=25“, „method“: „GET“, „query“: { „_dc“: „1434121650378“, „page“: „1“, „start“: „0“, „limit“: „25“, „module“: „backend“, „controller“: „widgets“, „action“: „getVisitors“ }, „post“: } Den gleichen Fehler - jede Woche als Error Report per Mail - habe ich noch mit: „uri“: „/backend/widgets/getLastOrders?_dc=1434121650289&page=1&start=0&limit=25“ Was kann das sein? Und wie bekomme ich das behoben? Danke! Henning
Hallo, hast du Backend-Benutzer mit eingeschränkten Rechten? Die Fehlermeldung sagt eigentlich nur aus, dass jemand z.B. das Widget “Letzte Bestellungen” eingebunden hat, darauf aber kein Zugriff hat. Grüße Moritz
Hallo Moritz, danke erstmal for die Nachricht, aber an den Rechten Kann (?) es nicht liegen. ich habe nur zwei Nutzer, beide haben “local_Admin” als Rechteeinstellung. Hast Du (oder jemand sonst) eine Idee wie ich das Problem gelöst bekomme? Ich hatte tatsächlich gehofft das es eventuell hiermit: post123347.html zusammenhängt… aber das ist dann wohl nicht so… Trotzdem danke!
