Error Meldung 'Enlight_Controller_Exception'
Hallo!
Kann mir jemand helfen dieses Fehler zu beseitigen. Bekomme es sporadisch per Mail:
Message:    exception ‚Enlight_Controller_Exception‘ with message ‚Unauthorized‘ in /www/htdocs/www/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:202
Stack trace:
#0 /www/htdocs/www/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs))
#1 /www/htdocs/www/engine/Library/Enlight/Event/EventManager.php(213): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /www/htdocs/www/engine/Library/Enlight/Controller/Action.php(137): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#3 /www/htdocs/www/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚getVisitorsActi…‘)
#4 /www/htdocs/www/engine/Library/Enlight/Controller/Front.php(226): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /www/htdocs/www/engine/Shopware/Kernel.php(153): Enlight_Controller_Front->dispatch()
#6 /www/htdocs/www/vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /www/htdocs/www/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 /www/htdocs/www/vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /www/htdocs/www/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /www/htdocs/www/shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#11 {main}
Time:    2016-03-27T03:29:34.159737+0200
Channel:    core
request:    {
    „uri“: „/backend/widgets/getVisitors?_dc=1459042174286&page=1&start=0&limit=25“,
    „method“: „GET“,
    „query“: {
        „_dc“: „1459042174286“,
        „page“: „1“,
        „start“: „0“,
        „limit“: „25“,
        „module“: „backend“,
        „controller“: „widgets“,
        „action“: „getVisitors“
    „post“:
session:    No session data available
shop:    No shop data available
die Meldung bekommst du, wenn du im Backend ausgeloggt bist aber es noch offen hast.
Es hat also nichts zu bedeuten.
Gruß Heiner
