Was ist die Ursache?
Enlight_Controller_Exception: Unauthorized in /home/httpd/vhosts/…/shop/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:212
Stack trace:
#0 /home/httpd/vhosts/…/shop/engine/Library/Enlight/Event/Handler/Plugin.php(145): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs))
#1 /home/httpd/vhosts/…/shop/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /home/httpd/vhosts/…/shop/engine/Library/Enlight/Controller/Action.php(162): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#3 /home/httpd/vhosts/…/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch(‚loadAction‘)
#4 /home/httpd/vhosts/…/shop/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /home/httpd/vhosts/…/shop/engine/Shopware/Kernel.php(191): Enlight_Controller_Front->dispatch()
#6 /home/httpd/vhosts/…/shop/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /home/httpd/vhosts/…/shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 /home/httpd/vhosts/…/shop/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#9 /home/httpd/vhosts/…/shop/vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /home/httpd/vhosts/…/shop/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /home/httpd/vhosts/…/shop/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#12 {main}
Time:
2021-09-09T15:37:52.739844+0200
Channel:
core
request:
„uri“: „/backend/customer/load/?no-cache=1630998637+1+1“,
„method“: „POST“,
„query“: {
„no-cache“: „1630998637 1 1“,
„module“: „backend“,
„controller“: „customer“,
„action“: „load“
„post“: {
„file“: [
„model/Customer“,
„model/Debit“,
„model/PaymentData“,
„model/Order“,
„model/Chart“,
„model/Batch“,
„model/Address“,
„model/QuickView“,
„model/CustomerStream“,
„view/main/QuickView“,
„view/main/StreamView“,
„view/main/CustomerList“,
„view/main/CustomerListFilter“,
„view/main/Window“,
„view/main/Wizard“,
„view/detail/Window“,
„view/detail/Base“,
„view/detail/Debit“,
„view/detail/Comment“,
„view/detail/Additional“,
„view/order/List“,
„view/order/Chart“,
„view/address/List“,
„view/address/detail/Window“,
„view/address/detail/Address“,
„view/chart/AmountChartFactory“,
„view/chart/Chart“,
„view/chart/MetaChart“,
„view/customer_stream/Detail“,
„view/customer_stream/Listing“,
„view/customer_stream/Preview“,
„view/customer_stream/ConditionPanel“,
„view/customer_stream/ConditionField“,
„view/customer_stream/conditions/AccountModeCondition“,
„view/customer_stream/conditions/AgeCondition“,
„view/customer_stream/conditions/HasAddressWithCountryCondition“,
„view/customer_stream/conditions/HasCanceledOrdersCondition“,
„view/customer_stream/conditions/HasNewsletterRegistrationCondition“,
„view/customer_stream/conditions/IsCustomerSinceCondition“,
„view/customer_stream/conditions/IsInCustomerGroupCondition“,
„view/customer_stream/conditions/HasOrderCountCondition“,
„view/customer_stream/conditions/OrderedAtWeekdayCondition“,
„view/customer_stream/conditions/OrderedInLastDaysCondition“,
„view/customer_stream/conditions/OrderedInShopCondition“,
„view/customer_stream/conditions/RegisteredInShopCondition“,
„view/customer_stream/conditions/OrderedOnDeviceCondition“,
„view/customer_stream/conditions/OrderedProductCondition“,
„view/customer_stream/conditions/OrderedProductOfCategoryCondition“,
„view/customer_stream/conditions/OrderedProductOfManufacturerCondition“,
„view/customer_stream/conditions/OrderedWithDeliveryCondition“,
„view/customer_stream/conditions/OrderedWithPaymentCondition“,
„view/customer_stream/conditions/HasTotalOrderAmountCondition“,
„view/customer_stream/conditions/CustomerAttributeCondition“,
„view/customer_stream/conditions/SalutationCondition“,
„view/customer_stream/conditions/SearchTermCondition“,
„view/customer_stream/conditions/field/AttributeValue“,
„view/customer_stream/conditions/field/AttributeWindow“,
„view/customer_stream/conditions/field/OperatorField“,
„store/Detail“,
„store/Orders“,
„store/Chart“,
„store/Batch“,
„store/Address“,
„store/QuickView“,
„store/Preview“,
„store/CustomerStream“,
„controller/Detail“,
„controller/Order“,
„controller/Main“,
„controller/Stream“
shop:
No shop data available
session:
No session data available
