Liebes Forum
ich bekomme im Backend oft folgende Fehlermeldung:
exception ‚Enlight_Controller_Exception‘ with message ‚Unauthorized‘ in /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:202
Stack trace:
#0 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs))
#1 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(138): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#3 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚getLastOrdersAc…‘)
#4 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#6 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /var/www/vhosts/meinshop.de/httpdocs/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#11 {main}
2017-04-28T12:41:56.926278+0200
core
„uri“: „/backend/widgets/getLastOrders?_dc=1493376116500&page=1&start=0&limit=25“,
„method“: „GET“,
„query“: {
„_dc“: „1493376116500“,
„page“: „1“,
„start“: „0“,
„limit“: „25“,
„module“: „backend“,
„controller“: „widgets“,
„action“: „getLastOrders“
„post“:
No shop data available
No session data available
Also wenn ich die letzten Bestellungen betrachte. Ganz ähnliche Fehlermeldungen bekomme ich bei getVisitors und getTurnOverVisitors und wahrscheinlich auch noch bei weiteren. Es ist immer die gleiche php-Programmzeile.
Die Fehlermeldung erhalte ich nur als Email, bei der Bedienung im Backend bin merke ich davon nichts.
Woran könnte das denn liegen ?
Liebe Grüße
Kerstin
