'Unauthorized' Backend Fehlermeldungen
Ich bekomme sporadisch diese Fehlermeldungen per Mail.
Die Fehler werden von mir selbst bzw. vom Safari unter MacOS ausgelöst.
Was den Fehler allerdings genau triggert weis ich nicht.
Es kommen immer diese drei Melungen in drei seperaten Mails:
ERROR
Message:
exception 'Enlight_Controller_Exception' with message 'Unauthorized' in /var/www/vhosts/shopware/docroot/engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:206
Stack trace:
#0 /var/www/vhosts/shopware/docroot/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs))
#1 /var/www/vhosts/shopware/docroot/engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#2 /var/www/vhosts/shopware/docroot/engine/Library/Enlight/Controller/Action.php(138): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#3 /var/www/vhosts/shopware/docroot/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('getVisitorsActi...')
#4 /var/www/vhosts/shopware/docroot/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#5 /var/www/vhosts/shopware/docroot/engine/Shopware/Kernel.php(180): Enlight_Controller_Front->dispatch()
#6 /var/www/vhosts/shopware/docroot/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /var/www/vhosts/shopware/docroot/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 /var/www/vhosts/shopware/docroot/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /var/www/vhosts/shopware/docroot/engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /var/www/vhosts/shopware/docroot/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#11 {main}
Time:
2017-02-13T20:50:10.303257+0100
Channel:
core
request:
    "uri": "/backend/widgets/getVisitors?_dc=1487015381116&page=1&start=0&limit=25",
    "method": "GET",
    "query": {
        "_dc": "1487015381116",
        "page": "1",
        "start": "0",
        "limit": "25",
        "module": "backend",
        "controller": "widgets",
        "action": "getVisitors"
    "post": []
shop:
No shop data available
session:
No session data available
ERROR
Message:
Stack trace:
#3 /var/www/vhosts/shopware/docroot/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('getLastOrdersAc...')
#11 {main}
Time:
2017-02-13T20:50:10.251920+0100
Channel:
core
request:
    "uri": "/backend/widgets/getLastOrders?_dc=1487015381003&page=1&start=0&limit=25",
    "method": "GET",
    "query": {
        "_dc": "1487015381003",
        "page": "1",
        "start": "0",
        "limit": "25",
        "action": "getLastOrders"
    "post": []
shop:
session:
ERROR
Message:
Stack trace:
#3 /var/www/vhosts/shopware/docroot/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('getTurnOverVisi...')
#11 {main}
Time:
Channel:
core
request:
    "uri": "/backend/widgets/getTurnOverVisitors?_dc=1487015381004&page=1&start=0&limit=25",
    "method": "GET",
    "query": {
        "_dc": "1487015381004",
        "page": "1",
        "start": "0",
        "limit": "25",
        "action": "getTurnOverVisitors"
    "post": []
shop:
session:
Ich kriege sehr häufig die selben drei Mails? Herausgefunden woran es liegt?
Das passiert bei einem backend timeout. Du bist quasi schon ausgeloggt und im Hintergrund werden die Widgets aktualisiert. Die Fehlermeldung entsteht nur im backend wenn man was abrufen will, worauf man keinen Zugriff hat. In der Meldung oben stehen die Widgets im Stacktrace.
Also ihr seid da schon dran, das ist schön zu hören.
