Ich bekomme beim Update folgende Fehlermeldung „Shopware konnte nicht aktualisiert werden. Klicke [hier]um zur Protokolldatei zu gelangen.“
Hat jemand eine Idee?
Protokoll
Run Update preparations
> pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
> pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.008 seconds
Analyzed 1009 packages to resolve dependencies
Analyzed 8721 rules to resolve dependencies
Nothing to modify in lock file
Dependency resolution completed in 0.001 seconds
Installing dependencies from lock file (including require-dev)
> pre-operations-exec: Symfony\Flex\Flex->recordOperations
Nothing to install, update or remove
Package php-http/message-factory is abandoned, you should avoid using it. Use psr/http-factory instead.
Generating optimized autoload files
> post-autoload-dump: Symfony\Component\Runtime\Internal\ComposerPlugin->updateAutoloadFile
110 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
> post-update-cmd: Symfony\Flex\Flex->update
Run composer recipes at any time to see the status of your Symfony recipes.
No security vulnerability advisories found
In InstallRecipesCommand.php line 58:
  [Symfony\Component\Console\Exception\RuntimeException]
  Cannot run "sync-recipes --force": git not found.
Exception trace:
  at /home/.sites/89/site2072/web/shop/vendor/symfony/flex/src/Command/InstallRecipesCommand.php:58
 Symfony\Flex\Command\InstallRecipesCommand->execute() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/symfony/console/Command/Command.php:312
 Symfony\Component\Console\Command\Command->run() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:1022
 Symfony\Component\Console\Application->doRunCommand() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:314
 Symfony\Component\Console\Application->doRun() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Console/Application.php:377
 Composer\Console\Application->doRun() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:168
 Symfony\Component\Console\Application->run() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Console/Application.php:141
 Composer\Console\Application->run() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/composer/composer/bin/composer:89
 include() at phar:///home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php/vendor/bin/composer:120
 require() at /home/.sites/89/site2072/web/shop/public/shopware-installer.phar.php:44
symfony:recipes:install [--force] [--reset] [--] [...]
