ich habe heute ein Update von 6.4.20 auf 6.5.6.1 versucht und bin im update Prozess mit einem Fehler konfrontiert worden. Danach hab ich das update erneut gestartet und es ist durchgelaufen. Seither funktioniert weder Front-End noch Back-End „500 Internal Server Error“
Log-Datei
Run Update preparations
pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.013 seconds
Analyzed 1118 packages to resolve dependencies
Analyzed 9932 rules to resolve dependencies
Nothing to modify in lock file
Dependency resolution completed in 0.001 seconds
Installing dependencies from lock file (including require-dev)
pre-operations-exec: Symfony\Flex\Flex->recordOperations
Nothing to install, update or remove
Generating optimized autoload files
Warning: Ambiguous class resolution, „SebastianBergmann\Type\StaticType“ was found in both „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/StaticType.php“ and „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/type/StaticType.php“, the first will be used.
Warning: Ambiguous class resolution, „SebastianBergmann\Type\UnionType“ was found in both „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/UnionType.php“ and „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/type/UnionType.php“, the first will be used.
Warning: Ambiguous class resolution, „SebastianBergmann\Type\FalseType“ was found in both „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/FalseType.php“ and „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/type/FalseType.php“, the first will be used.
Warning: Ambiguous class resolution, „SebastianBergmann\Type\MixedType“ was found in both „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/type/MixedType.php“ and „/home/.sites/8/site5123681/web/vendor/sebastian/type/src/MixedType.php“, the first will be used.
post-autoload-dump: Symfony\Component\Runtime\Internal\ComposerPlugin->updateAutoloadFile
139 packages you are using are looking for funding.
Use thecomposer fundcommand to find out more!
post-update-cmd: Symfony\Flex\Flex->update
Run composer recipes at any time to see the status of your Symfony recipes.
No security vulnerability advisories found
In InstallRecipesCommand.php line 58:
[Symfony\Component\Console\Exception\RuntimeException]
Cannot run „sync-recipes --force“: git not found.
Exception trace:
at /home/.sites/8/site5123681/web/vendor/symfony/flex/src/Command/InstallRecipesCommand.php:58
Symfony\Flex\Command\InstallRecipesCommand->execute() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/symfony/console/Command/Command.php:326
Symfony\Component\Console\Command\Command->run() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:1063
Symfony\Component\Console\Application->doRunCommand() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:320
Symfony\Component\Console\Application->doRun() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Console/Application.php:378
Composer\Console\Application->doRun() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:174
Symfony\Component\Console\Application->run() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/composer/composer/src/Composer/Console/Application.php:141
Composer\Console\Application->run() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/composer/composer/bin/composer:89
include() at phar:///home/.sites/8/site5123681/web/public/shopware-installer.phar.php/vendor/bin/composer:119
require() at /home/.sites/8/site5123681/web/public/shopware-installer.phar.php:37
symfony:recipes:install [–force] [–reset] [–] […]
Kann mir da bitte jemand helfen.
Danke LG Günther
