Auch Ich habe das Update Gott sei dank erst in der Staging gemacht, lauter Fehlermeldungen siehe Logfile:
Run Update preparations
Updating to Flex Project
Updated to Flex Project
pre-update-cmd: Symfony\Flex\Flex->configureInstaller
Loading composer repositories with package information
pre-pool-create: Symfony\Flex\Flex->truncatePackages
Updating dependencies
Dependency resolution completed in 0.000 seconds
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Root composer.json requires frosh/mail-platform-archive 2.0.6 → satisfiable by frosh/mail-platform-archive[2.0.6].
- frosh/mail-platform-archive 2.0.6 requires shopware/core ~6.5.0 → found shopware/core[6.5.0.0, v6.5.1.0, v6.5.1.1, v6.5.2.0, v6.5.2.1, v6.5.3.0, v6.5.3.1, v6.5.3.2, v6.5.3.3, v6.5.4.0, v6.5.4.1, v6.5.5.0, v6.5.5.1, v6.5.5.2, v6.5.6.0, v6.5.6.1, v6.5.7.0, v6.5.7.1, v6.5.7.2, v6.5.7.3, v6.5.7.4, v6.5.8.0, v6.5.8.1, v6.5.8.2, v6.5.8.3, v6.5.8.4, v6.5.8.5, v6.5.8.6, v6.5.8.7, v6.5.8.8] but it conflicts with your root composer.json require (6.6.1.0).
Problem 2
- Root composer.json requires shopware/administration 6.6.1.0 → satisfiable by shopware/administration[v6.6.1.0].
- shopware/administration v6.6.1.0 requires php ~8.2.0 || ~8.3.0 → your php version (8.1.27) does not satisfy that requirement.
Problem 3
- Root composer.json requires shopware/core 6.6.1.0 → satisfiable by shopware/core[v6.6.1.0].
- shopware/core v6.6.1.0 requires php ~8.2.0 || ~8.3.0 → your php version (8.1.27) does not satisfy that requirement.
Problem 4
- Root composer.json requires shopware/elasticsearch 6.6.1.0 → satisfiable by shopware/elasticsearch[v6.6.1.0].
- shopware/elasticsearch v6.6.1.0 requires php ~8.2.0 || ~8.3.0 → your php version (8.1.27) does not satisfy that requirement.
Problem 5
- Root composer.json requires shopware/storefront 6.6.1.0 → satisfiable by shopware/storefront[v6.6.1.0].
- shopware/storefront v6.6.1.0 requires php ~8.2.0 || ~8.3.0 → your php version (8.1.27) does not satisfy that requirement.
Problem 6
- teamnovu/shopware-cookie-accept-plugin 1.0.10 requires shopware/core ~6.5 → satisfiable by shopware/core[v6.6.1.0].
- Root composer.json requires teamnovu/shopware-cookie-accept-plugin 1.0.10 → satisfiable by teamnovu/shopware-cookie-accept-plugin[1.0.10].
Use the option --with-all-dependencies (-W) to allow upgrades, downgrades and removals for packages currently locked to specific versions.
