in betreue einen bestehenden Shop an dem offenbar schon „vor meiner Zeit“ an diesem Thema gerabeitet worden ist.
In den Kategorienattributen wurde eine Checkbox „hide_in_sidebar“ reingenommen.
Und so sieht unter /frontend/index die sidebar-categories.tpl aus:
{extends file='parent:frontend/index/sidebar-categories.tpl'}
{* Maincategories left *}
{function name=categories level=0}
<ul class="sidebar--navigation categories--navigation navigation--list{if !$level} is--drop-down{/if} is--level{$level}{if $level > 1} navigation--level-high{/if} is--rounded" role="menu">
{* @deprecated The block "frontend_index_categories_left_ul" will be removed in further versions, please use "frontend_index_categories_left_before" *}
{block name="frontend_index_categories_left_ul"}{/block}
{block name="frontend_index_categories_left_before"}{/block}
{foreach $categories as $category}
{if $category['attribute']['hide_in_sidebar']}
{continue}
{/if}
{block name="frontend_index_categories_left_entry"}
<li class="navigation--entry{if $category.flag} is--active{/if}{if $category.subcategories} has--sub-categories{/if}{if $category.childrenCount} has--sub-children{/if}" role="menuitem">
<a class="navigation--link{if $category.flag} is--active{/if}{if $category.subcategories} has--sub-categories{/if}{if $category.childrenCount} link--go-forward{/if}"
href="{$category.link}"
data-categoryId="{$category.id}"
data-fetchUrl="{url module=widgets controller=listing action=getCategory categoryId={$category.id}}"
title="{$category.description|escape}">
{$category.description}
<span class="is--icon-right">
<i class="icon--arrow-right"></i>
</span>
{/if}
</a>
{block name="frontend_index_categories_left_entry_subcategories"}
{call name=categories categories=$category.subcategories level=$level+1}
{/if}
{/block}
</li>
{/block}
{/foreach}
{block name="frontend_index_categories_left_after"}{/block}
</ul>
{/function}
{if $sCategories}
{call name=categories categories=$sCategories}
{elseif $sMainCategories}
{call name=categories categories=$sMainCategories}
{/if}
Ich verstehe es so, dass wenn das Flag für Kategorieebene 0 gesetzt ist, diese eigentlich ausgeblendet werden sollte. Passiert aber nicht. Habt ihr eine Idee woran das liegt?
Bin jetzt nicht der Programmierer.
Danke und Gruß
pino
