Hallo zusammen, ich erhalte beim Aufruf des Staging-Systems unter staging.domain.tld/backend/ folgende Fehlermeldung: Fatal error: Uncaught exception 'PDOException' with message 'SQLSTATE[42S02]: Base table or view not found: 1146 Table 'datenbank\_staging.s\_core\_sessions\_backend' doesn't exist' in /var/www/vhosts/domain.tld/httpdocs/engine/Library/Zend/Db/Statement/Pdo.php:228 Stack trace: #0 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Zend/Db/Statement/Pdo.php(228): PDOStatement-\>execute(Array) #1 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Zend/Db/Statement.php(300): Zend\_Db\_Statement\_Pdo-\>\_execute(Array) #2 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Zend/Db/Adapter/Abstract.php(479): Zend\_Db\_Statement-\>execute(Array) #3 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend\_Db\_Adapter\_Abstract-\>query('DESCRIBE `s_cor...', Array) #4 /var/www/vhosts/domain.tld/httpdocs/engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(75): Zend_Db_Adapter_Pdo_Abstract-\>query('DESCRIBE `s\_cor...', Array) #5 /var/www/vhosts/domain.tld/httpdocs/en in /var/www/vhosts/domain.tld/httpdocs/engine/Library/Zend/Db/Statement/Pdo.php on line 234 …und im Frontend folgende Fehlermeldung: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'datenbank\_staging.s\_articles\_categories\_ro' doesn't exist in Doctrine/DBAL/Connection.php on line 628 Stack trace: #0 Doctrine/DBAL/Connection.php(628): PDOStatement-\>execute() #1 Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(46): Doctrine\DBAL\Connection-\>executeQuery('SELECT COUNT(s0...', Array, Array, NULL) #2 Doctrine/ORM/Query.php(260): Doctrine\ORM\Query\Exec\SingleSelectExecutor-\>execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 Doctrine/ORM/AbstractQuery.php(595): Doctrine\ORM\Query-\>\_doExecute() #4 Doctrine/ORM/AbstractQuery.php(432): Doctrine\ORM\AbstractQuery-\>execute(Array, 2) #5 engine/core/class/sCategories.php(257): Doctrine\ORM\AbstractQuery-\>getArrayResult() #6 Shopware/Controllers/Frontend/Index.php(44): sCategories-\>sGetCategoryContent(3) #7 Enlight/Controller/Action.php(148): Shopware\_Controllers\_Frontend\_Index-\>indexAction() #8 Enlight/Controller/Dispatcher/Default.php(521): Enlight\_Controller\_Action-\>dispatch('indexAction') #9 Enlight/Controller/Front.php(214): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 Shopware/Components/HttpCache/HttpKernel.php(79): Enlight\_Controller\_Front-\>dispatch() #11 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(434): Shopware\Components\HttpCache\HttpKernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 Shopware/Components/HttpCache/AppCache.php(234): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(403): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(303): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #15 Shopware/Components/HttpCache/AppCache.php(158): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #16 Symfony/Component/HttpKernel/HttpCache/HttpCache.php(192): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #17 Shopware/Components/HttpCache/AppCache.php(110): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 Shopware/Bootstrap.php(70): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #19 Enlight/Application.php(192): Shopware\_Bootstrap-\>run() #20 shopware.php(83): Enlight\_Application-\>run() #21 {main} Was muss ich nach dem Update auf 4.1 noch ändern? In der Update-Anleitung steht nichts davon, dass man das Staging noch neu einrichten muss.
Betreibt von euch keiner das Staging-System bzw. hat noch keiner bei einem bestehenden Staging-System von 4.0.8 auf 4.1.0 geupdatet? Hat das Update bei euch problemlos funktioniert oder musste im Staging-System noch was angepasst werden? Würde mich über ein Feedback freuen!
Hi Christian, das Staging Modul ist noch nicht für die 4.1er Version freigegeben. Die Entwicklung ist momentan dabei dies 4.1 Kompatibel zu machen. Wann genau dies jedoch für die 4.1 freigegeben wird kann ich dir nicht sagen. Gruß Dennis
Hallo Dennis, vielen Dank für die Info! Ohje… jetzt muss ich mir für die Tests wohl doch noch eine “Spielwiese” einrichten. Wenn man sich erstmal an das staging gewöhnt hat. Ist schon ne feine Sache! Es wäre natürlich klasse, wenn das kompatible staging-Plugin zeitnah für die 4.1 freigegeben werden würde.
