wir bekommen leider beim Update die Fehlermeldung "Command „update“ is not defined. " sowohl über den Console als auch über dem Admin.
Sehe unten die Infos aus dem Logfile. Jeder Hinweis würde sehr geschätzt. Dank vorab.
Run Update preparations
Updating to Flex Project
Updated to Flex Project
[critical] Error thrown while running command "update -d '/home/user/PhpstormProjects/skatestore.local' --no-interaction --no-ansi --no-scripts -v --with-all-dependencies". Message: "Command "update" is not defined."
In Application.php line 725:
[Symfony\Component\Console\Exception\CommandNotFoundException]
Exception trace:
at phar:///home/user/PhpstormProjects/skatestore.local/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:725
Symfony\Component\Console\Application->find() at phar:///home/user/PhpstormProjects/skatestore.local/public/shopware-installer.phar.php/vendor/symfony/framework-bundle/Console/Application.php:108
Symfony\Bundle\FrameworkBundle\Console\Application->find() at phar:///home/user/PhpstormProjects/skatestore.local/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:262
Symfony\Component\Console\Application->doRun() at phar:///home/user/PhpstormProjects/skatestore.local/public/shopware-installer.phar.php/vendor/symfony/framework-bundle/Console/Application.php:80
Symfony\Bundle\FrameworkBundle\Console\Application->doRun() at phar:///home/user/PhpstormProjects/skatestore.local/public/shopware-installer.phar.php/vendor/symfony/console/Application.php:174
Symfony\Component\Console\Application->run() at phar:///home/user/PhpstormProjects/skatestore.local/public/shopware-installer.phar.php/bin/console:15
require() at /home/user/PhpstormProjects/skatestore.local/public/shopware-installer.phar.php:46```
