Hallo, ich habe mir heute den Rakuten Checkout installiert und gerade testen wollen. Nach dem Klick auf “Zahlungspflichtig bestellen” kommt das hier: array (3) {[“Erfolg”] => string (5) “false” [“code”] => string (3) “110” [“message”] => string (264) "Kann SELECT-Anweisung ausführen [SELECT token.ID, token.TOKEN, token.MODIFIED, token.LIFETIME, token.FINGERPRINT, FROM Token WHERE token.TOKEN = token.UID: p1 LIMIT 1] [gewickelt: SQLSTATE [42S22]: Column not found : 1054 Unknown column ‘token.UID’ in ‘field list’] "} Array ([content] => Array ([0] => Array ([id] => 681 [sessionID] => ae9e80d4c09a4478aa8154baa94e77302a0dc77b [userID] => 3 [Artikelname] => MÃ ¼ tze Vintage-Driver [articleID] => 145 [Bestellnummer] => SW10145 [shippingfree] => 0 [Anzahl] => 1 [price] => 17,99 [Nettopreis] => 15,117647058824 [tax_rate] => 19 [Datum] => 2012.10.11 16.35.35 [modus] => 0 [esdarticle] => 0 [PartnerID] => [lastviewport] => Kasse [useragent] => Mozilla/5.0 ( Windows NT 6.0) AppleWebKit/537.4 (KHTML, like Gecko) Chrome/22.0.1229.94 Safari/537.4 [config] => [currencyFactor] => 1 [liveshoppingID] => 0 [Bundlekennung] => 0 [bundle_join_ordernumber] => [packunit] => [minpurchase] => 1 [taxID] => 1 [instock] => 397 [suppliernumber] => [maxpurchase] => 100 [purchasesteps] => 1 [purchaseunit] => [laststock] => 0 [lieferzeit] => [Releasedate] => [sReleaseDate] => [stockmin] => 0 [itemUnit] => [ob_attr1] => [ob_attr2] => [ob_attr3] => [ob_attr4] => [ob_attr5] = > [ob_attr6] => [Versandinfos] => 1 [esd] => 0 [additional_details] => Array ([articleID] => 145 [articleDetailsID] => 292 [Bestellnummer] => SW10145 [Datum] => 2012 - 08-20 [sales] => 0 [highlight] => 0 [description] => abeo repere nam Familia lignarius cado sesquimellesimus Se, volo tergo duco Dictator pro SOCU. [DESCRIPTION_LONG] => abeo repere nam Familia lignarius cado sesquimellesimus Se, volo tergo duco Dictator pro SOCU. [supplierName] => Vintage Driver [supplierImg] => media / image / vintage.png [Artikelname] => MÃ ¼ tze Vintage-Driver [taxID] => 1 [price] => 17,99 [pseudoprice] => 19,99 [netto] => 19,00 [attr1] => [attr2] => [attr3] => [attr4] => [attr5] => [attr6] => [attr7] => [attr8] => [attr9] => [attr10] => [attr11] => [attr12] => [attr13] => [attr14] => [attr15] => [attr16] => [attr17] => [attr18] => [attr19] => [attr20] => [instock] => 397 [weight] => 0,000 [lieferzeit] => [Preisgruppe] => EK [pricegroupID] => [pricegroupActive] => 0 [filtergroupID] = > [purchaseunit] => 0 [referenceunit] => 0 [UnitID] => [laststock] => 0 [additionalText] => [sConfigurator] => 0 [esd] => 0 [sVoteAverange] => Array ([averange] => 0 [count] => 0) [newArticle] => 0 [Topseller] => 0 [sUpcoming] => 0 [sReleasedate] => [sVariantArticle] => [pseudopricePercent] => Array ([int] = > 10 [float] => 10,01) [Bild] => Array ([src] => Array ([original] => [0] => [1] => [2] => [3] => [4] => [5] => ) [Res] => Array ([original] => Array ([width] => 0 [height] => 0) [description] =>) [position] => 1 [Erweiterung] => jpg [main] = > 1 [id] => 610 [parentId] => [Attribut] => Array ()) [linkBasket] => shopware.php? sViewport = Korb & Sadd = SW10145 [linkDetails] => shopware.php? sViewport = detail & sArticle = 145 [properties] =>) [Betrag] => 17,99 [amountnet] => 15,12 [priceNumeric] => 17,99 [Bild] => Array ([src] => Array ([original] => [0] => [1] => [2] => [3] => [4] => [5] => ) [Res] => Array ([original] => Array ([width] => 0 [height] => 0) [description] =>) [position] => 1 [Erweiterung] => jpg [main] = > 1 [id] => 610 [parentId] => [Attribut] => Array ()) [linkDetails] => shopware.php? sViewport = detail & sArticle = 145 [linkDelete] => shopware.php? sViewport = Korb & SDelete = 681 [linkNote] => shopware.php? sViewport = Note & Sadd = SW10145 [netto] => 2,87)) [Amount] => 17,99 [AmountNet] => 15,12 [Anzahl] => 1 [AmountNumeric] = > 22,94 [AmountNetNumeric] => 19,277647058824 [AmountWithTax] => 0 [AmountWithTaxNumeric] => 0 [sLastActiveArticle] => Array ([id] => 145 [link] => shopware.php? sViewport = detail & sDetails = 145) [sShippingcostsWithTax] => 4,95 [sShippingcostsNet] => 4,16 [sShippingcostsTax] => 19 [sShippingcostsDifference] => [sTaxRates] => Array ([19,00] => 3,66) [sShippingcosts] => 4,95 [sAmount] => 22,94 [sAmountTax] => 3,66) Inhalt Warenkorb: 1 Ist das nun ein Fehler bei Shopware oder muß ich mich an Rakuten wenden?
Wo ist das Rakuten Checkout Plugin zum Download erhältlich?
Hier: http://www.rakuten.de/checkout/integration/uebersicht und hier muß Du Dich registrieren: http://www.rakuten.de/checkout/haendler/registrierung
Geh mal davon aus, dass das Plugin nicht für die 4er-Version gedacht ist. Aber am besten bei denen nachfragen, die es programmiert haben bzw. bereitsstellen.
Da dort steht „Kompatible Version: Ab Version 3.5.4“ dachte ich es wär für alle. Habe an den Rakuten Support geschrieben und dieser hat mir folgendes mitgeteilt: " Das Shopware Modul wurde von Shopware direkt geschrieben daher übernehmen diese auch den Support hierfür."
Du hast doch sicher das Downloadpaket noch. Entzippe das mal und öffne eine der php-Dateien. Ganz oben im Code findest Du den Eintrag, wer Support dafür macht.
Aha, danke, da steht folgendes drin: @support support@drow.de
Jepps, dann solltest Du Dich an die wenden.
Jawolla, Mail ist schon raus.
Gibt es da schon neue Erkenntnisse, ob der Rakuten Checkout auch als Plugin für Shopware 4 geeignet ist?
Leider nicht. Ich habe nur zur Antwort bekommen das es das für Shopware 4 noch nicht gibt. Gibts hier vielleicht einen Programmierer im Forum der mir das anpassen könnte?
Da wäre ich ebenfalls sehr interessiert.
So ich habe Neuigkeiten: Im Rakutenforum wird berichtet, dass die Integration für Shopware 4.0.4 nur klappt, wenn man das anpassen lässt (Programmierer, s.o.]. Link bringt nichts, da das nur für Händler/Partner zugänglich ist (ich bin noch(!) beides). Rakuten selbst teilte mir auf meinen Hinweis, dass die Kompatibilität falsch ausgewiesen wird, folgendes mit: [quote]vielen Dank für den Hinweis. Dass Version 4 nicht kompatibel ist, ist uns bekannt – wir werden den Hinweis darauf auf unserer Seite anpassen. Ein Update unsererseits ist derzeit nicht geplant – […]abgerissener Kontakt zum Entwickler[…] daher aktuell kein Support mehr.[/quote] Soweit der Stand. Fazit: selbst ist der Shopbetreiber
Wenn ich hier eine Lösung habe, werde ich sie posten.
