Shopware-Installer auf xampp installieren
ich versuche gerade die Installatiion mit dem Installer durchzuführen - leider bekomme ich den Fehler:
Shopware konnte nicht heruntergeladen werden. Klicke hier um zur Protokolldatei zu gelangen.
In der Protokolldatei steht nichts konkretes:
Usage: C:\xampp\apache\bin\httpd.exe [-D name] [-d directory] [-f file]
[-C „directive“] [-c „directive“]
[-w] [-k start|restart|stop|shutdown] [-n service_name]
[-k install|config|uninstall] [-n service_name]
[-v] [-V] [-h] [-l] [-L] [-t] [-T] [-S] [-X]
Options:
-D name : define a name for use in directives
-d directory : specify an alternate initial ServerRoot
-f file : specify an alternate ServerConfigFile
-C „directive“ : process directive before reading config files
-c „directive“ : process directive after reading config files
-n name : set service name and use its ServerConfigFile and ServerRoot
-k start : tell Apache to start
-k restart : tell running Apache to do a graceful restart
-k stop|shutdown : tell running Apache to shutdown
-k install : install an Apache service
-k config : change startup Options of an Apache service
-k uninstall : uninstall an Apache service
-w : hold open the console window on error
-e level : show startup errors of level (see LogLevel)
-E file : log startup errors to file
-v : show version number
-V : show compile settings
-h : list available command line options (this page)
-l : list compiled in modules
-L : list available configuration directives
-t -D DUMP_VHOSTS : show parsed vhost settings
-t -D DUMP_RUN_CFG : show parsed run settings
-S : a synonym for -t -D DUMP_VHOSTS -D DUMP_RUN_CFG
-t -D DUMP_MODULES : show all loaded modules
-M : a synonym for -t -D DUMP_MODULES
-t -D DUMP_INCLUDES: show all included configuration files
-t : run syntax check for config files
-T : start without DocumentRoot(s) check
-X : debug mode (only one worker, do not detach)
Was kann ich hier tun? Fehlen zusätzliche Module, der Port sollte frei sein, da läuft nichts neben her!
Danke
Hallo @frankillner und herzlich willkommen hier im Forum!
Am besten: Finger weg von XAMPP, schau Dir stattdessen lieber dockware.io an :wink:
Unterstreiche ich auch gerne tausendfach und fett - lass das, nimm docker bevor du in den Wahnsinn abrutscht. Bin da auch vom alten Schlag, aber xampp muss sich keiner mehr antun heute.
