Hello,
First of all i appreciate Shopware Team You all are doing great Job. Anytime you are active for resolving our queries and give us a best solution for this Hats Off.
My query is related about item variants
Using Shopware Variants Configuration
i have make two active group which is color and size
in color group i have set two options 1)Red and 2)Blue
in Size group i have set 3 options 1)S 2)L 3)XL
now in frontend detail page when i select Red color field the 3 Size fields should be enable 1)S 2)L 3)XL
but when i select Blue Color field the all 3 Size Field (S, L, XL ) fields should be disable.
i have set it using set dependency but when i applied with blue color (Not With) (S, L, XL)
it hides the blue color field as well and not working properly as i need ???
So how can i resolve this issue???
