nach dem Update komme ich nicht mehr ins Backend rein es scheint diese fehlercode:
An exception occurred while executing ‘SELECT t0.id AS id_1, t0.name AS name_2, t0.plugin_name AS plugin_name_3, t0.service AS service_4 FROM webcu_marketplace t0’: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘t0.service’ in ‘field list’ in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 131
Stack trace:
#0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(855): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), 'SELECT t0.id AS...', Array) #1 engine/Library/Doctrine/ORM/Persisters/Entity/BasicEntityPersister.php(914): Doctrine\DBAL\Connection-\>executeQuery('SELECT t0.id AS...', Array, Array) #2 vendor/doctrine/orm/lib/Doctrine/ORM/EntityRepository.php(181): Doctrine\ORM\Persisters\Entity\BasicEntityPersister-\>loadAll(Array, NULL, NULL, NULL) #3 vendor/doctrine/orm/lib/Doctrine/ORM/EntityRepository.php(164): Doctrine\ORM\EntityRepository-\>findBy(Array) #4 custom/plugins/WebcuMarketplaceConnector/Components/MarketplaceConnector.php(72): Doctrine\ORM\EntityRepository-\>findAll() #5 custom/plugins/WebcuMarketplaceConnector/Subscriber/BackendMessage.php(51): WebcuMarketplaceConnector\Components\MarketplaceConnector::getMarketplaceList() #6 [internal function]: WebcuMarketplaceConnector\Subscriber\BackendMessage-\>onBackend(Object(Enlight\_Controller\_ActionEventArgs)) #7 engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs)) #8 engine/Library/Enlight/Event/EventManager.php(220): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #9 engine/Library/Enlight/Controller/Action.php(182): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #10 engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight\_Controller\_Action-\>dispatch('indexAction') #11 engine/Library/Enlight/Controller/Front.php(222): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #12 engine/Shopware/Kernel.php(215): Enlight\_Controller\_Front-\>dispatch() #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #15 vendor/symfony/http-kernel/HttpCache/HttpCache.php(253): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #16 engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #17 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #18 {main}
Sollte ich am besten den Back-up wieder einspielen ?
Oder kann man das auch manuell reparieren ?
Vielen Dank
MfG
