hallo
ich bekomme seit dem letzten update im backend die plugins nicht mehr geladen als auch die artikelübersicht.
ich bekomme folgenden fehler:
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. An exception occurred while executing ‘SELECT plugin.id, plugin.name, plugin.label, plugin.active, plugin.namespace, plugin.description, plugin.source, plugin.version as version, plugin.capability_update, plugin.capability_install, plugin.capability_enable, plugin.capability_secure_uninstall, plugin.update_version, plugin.translations, plugin.installation_date, forms.id as form_id, plugin.update_date, plugin.author, plugin.link, plugin.support, licence.id as __licence_id, licence.host as __licence_host, licence.type as __licence_type, licence.creation as __licence_creation, licence.expiration as __licence_expiration, licence.license as __licence_license FROM s_core_plugins plugin LEFT JOIN s_core_config_forms forms ON forms.plugin_id = plugin.id LEFT JOIN s_core_licenses licence ON licence.module = plugin.name WHERE (plugin.name != ‘PluginManager’) AND (plugin.capability_enable = 1) GROUP BY plugin.id ORDER BY active DESC, installation_date IS NULL ASC, installation_date DESC LIMIT 20000’: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘plugin.translations’ in ‘field list’ in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 119 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(836): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), ‘SELECT plugin.i…’, Array) #1 vendor/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): Doctrine\DBAL\Connection->executeQuery(‘SELECT plugin.i…’, Array, Array) #2 engine/Shopware/Bundle/PluginInstallerBundle/Service/PluginLocalService.php(81): Doctrine\DBAL\Query\QueryBuilder->execute() #3 engine/Shopware/Bundle/PluginInstallerBundle/Service/PluginViewService.php(163): Shopware\Bundle\PluginInstallerBundle\Service\PluginLocalService->getListing(Object(Shopware\Bundle\PluginInstallerBundle\Context\ListingRequest)) #4 engine/Shopware/Plugins/Default/Backend/PluginManager/Controllers/Backend/PluginManager.php(293): Shopware\Bundle\PluginInstallerBundle\Service\PluginViewService->getLocalListing(Object(Shopware\Bundle\PluginInstallerBundle\Context\ListingRequest)) #5 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_PluginManager->localListingAction() #6 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‘localListingAct…’) #7 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #8 engine/Shopware/Kernel.php(180): Enlight_Controller_Front->dispatch() #9 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #10 engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #12 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #13 shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #14 {main}
OK
vg
sebastian
