Hallo Ihr lieben , kann mir wer helfen.
Beim Einloggen im Backend kommt der Fehler.
Pluggins kann ich auch nicht mehr Bearbeiten.
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. An exception occurred while executing ‘SELECT s0_.id AS id_0, s0_.name AS name_1, s0_.label AS label_2, s0_.plugin_id AS plugin_id_3, s1_.id AS id_4, s1_.auth_id AS auth_id_5, s1_.column AS column_6, s1_.position AS position_7, s2_.id AS id_8, s2_.name AS name_9, s2_.label AS label_10, s2_.namespace AS namespace_11, s2_.source AS source_12, s2_.description AS description_13, s2_.active AS active_14, s2_.added AS added_15, s2_.installation_date AS installation_date_16, s2_.update_date AS update_date_17, s2_.refresh_date AS refresh_date_18, s2_.author AS author_19, s2_.copyright AS copyright_20, s2_.license AS license_21, s2_.version AS version_22, s2_.support AS support_23, s2_.changes AS changes_24, s2_.link AS link_25, s2_.update_version AS update_version_26, s2_.update_source AS update_source_27, s2_.capability_update AS capability_update_28, s2_.capability_install AS capability_install_29, s2_.capability_enable AS capability_enable_30, s2_.capability_secure_uninstall AS capability_secure_uninstall_31, s2_.translations AS translations_32 FROM s_core_widgets s0_ LEFT JOIN s_core_widget_views s1_ ON s0_.id = s1_.widget_id AND (s1_.auth_id = ?) LEFT JOIN s_core_plugins s2_ ON s0_.plugin_id = s2_.id WHERE s0_.plugin_id IS NULL OR s2_.active = 1 ORDER BY s1_.position ASC’ with params [54]: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘s2_.translations’ in ‘field list’ in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 119 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(836): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), ‘SELECT s0_.id A…’, Array) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection->executeQuery(‘SELECT s0_.id A…’, Array, Array, NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(321): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(969): Doctrine\ORM\Query->_doExecute() #4 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(924): Doctrine\ORM\AbstractQuery->executeIgnoreQueryCache(NULL, 2) #5 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(739): Doctrine\ORM\AbstractQuery->execute(NULL, 2) #6 engine/Shopware/Controllers/Backend/Widgets.php(60): Doctrine\ORM\AbstractQuery->getArrayResult() #7 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_Widgets->getListAction() #8 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‘getListAction’) #9 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #10 engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch() #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #16 {main}
OK
