Hallo zusammen, ich bekomme folgende Fehlermeldung beim Login in das Backend & beim klick auf “Bestellungen”: [2015-03-12 17:19:16] core.ERROR: exception 'PDOException' with message 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 's0\_.plugin\_id' in 'field list'' in /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:693 Stack trace: #0 /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(693): PDOStatement-\>execute() #1 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection-\>executeQuery('SELECT s0\_.id A...', Array, Array, NULL) #2 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor-\>execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query-\>\_doExecute() #4 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(586): Doctrine\ORM\AbstractQuery-\>execute(NULL, 2) #5 /pfad/zum/wwwroot/engine/Shopware/Controllers/Backend/Widgets.php(57): Doctrine\ORM\AbstractQuery-\>getArrayResult() #6 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_Widgets-\>getListAction() #7 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('getListAction') #8 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #9 /pfad/zum/wwwroot/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #10 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #12 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(243): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #13 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #14 /pfad/zum/wwwroot/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main} Next exception 'Doctrine\DBAL\DBALException' with message 'An exception occurred while executing 'SELECT s0\_.id AS id0, s0\_.name AS name1, s0\_.label AS label2, s0\_.plugin\_id AS plugin\_id3, s1\_.id AS id4, s1\_.auth\_id AS auth\_id5, s1\_.`column` AS column6, s1\_.position AS position7 FROM s\_core\_widgets s0\_ LEFT JOIN s\_core\_widget\_views s1\_ ON s0\_.id = s1\_.widget\_id AND (s1\_.auth\_id = ?) ORDER BY s1\_.position ASC' with params [60]: SQLSTATE[42S22]: Column not found: 1054 Unknown column 's0\_.plugin\_id' in 'field list'' in /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php:91 Stack trace: #0 /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(701): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(PDOException), 'SELECT s0\_.id A...', Array) #1 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection-\>executeQuery('SELECT s0\_.id A...', Array, Array, NULL) #2 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor-\>execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query-\>\_doExecute() #4 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(586): Doctrine\ORM\AbstractQuery-\>execute(NULL, 2) #5 /pfad/zum/wwwroot/engine/Shopware/Controllers/Backend/Widgets.php(57): Doctrine\ORM\AbstractQuery-\>getArrayResult() #6 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_Widgets-\>getListAction() #7 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('getListAction') #8 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #9 /pfad/zum/wwwroot/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #10 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #11 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #12 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(243): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #13 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #14 /pfad/zum/wwwroot/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main} [] {"uid":"04f8d45"} [2015-03-12 17:19:23] core.ERROR: exception 'PDOException' with message 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 's6\_.ean' in 'field list'' in /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:693 Stack trace: #0 /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(693): PDOStatement-\>execute() #1 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection-\>executeQuery('SELECT s0\_.id A...', Array, Array, NULL) #2 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor-\>execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query-\>\_doExecute() #4 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(574): Doctrine\ORM\AbstractQuery-\>execute(NULL, 2) #5 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Tools/Pagination/Paginator.php(186): Doctrine\ORM\AbstractQuery-\>getResult(2) #6 /pfad/zum/wwwroot/engine/Shopware/Controllers/Backend/Order.php(363): Doctrine\ORM\Tools\Pagination\Paginator-\>getIterator() #7 /pfad/zum/wwwroot/engine/Shopware/Controllers/Backend/Order.php(333): Shopware\_Controllers\_Backend\_Order-\>getList(NULL, NULL, '0', '20') #8 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_Order-\>getListAction() #9 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('getListAction') #10 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #11 /pfad/zum/wwwroot/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #12 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #14 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(243): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #15 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #16 /pfad/zum/wwwroot/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #17 {main} Next exception 'Doctrine\DBAL\DBALException' with message 'An exception occurred while executing 'SELECT s0\_.id AS id0, s0\_.ordernumber AS ordernumber1, s0\_.userID AS userID2, s0\_.status AS status3, s0\_.cleared AS cleared4, s0\_.paymentID AS paymentID5, s0\_.dispatchID AS dispatchID6, s0\_.partnerID AS partnerID7, s0\_.subshopID AS subshopID8, s0\_.invoice\_amount AS invoice\_amount9, s0\_.invoice\_amount\_net AS invoice\_amount\_net10, s0\_.invoice\_shipping AS invoice\_shipping11, s0\_.invoice\_shipping\_net AS invoice\_shipping\_net12, s0\_.ordertime AS ordertime13, s0\_.transactionID AS transactionID14, s0\_.comment AS comment15, s0\_.customercomment AS customercomment16, s0\_.internalcomment AS internalcomment17, s0\_.net AS net18, s0\_.taxfree AS taxfree19, s0\_.temporaryID AS temporaryID20, s0\_.referer AS referer21, s0\_.cleareddate AS cleareddate22, s0\_.trackingcode AS trackingcode23, s0\_.language AS language24, s0\_.currency AS currency25, s0\_.currencyfactor AS currencyfactor26, s0\_.remote\_addr AS remote\_addr27, s1\_.id AS id28, s1\_.name AS name29, s1\_.description AS description30, s1\_.template AS template31, s1\_.class AS class32, s1\_.`table` AS table33, s1\_.hide AS hide34, s1\_.additionaldescription AS additionaldescription35, s1\_.debit\_percent AS debit\_percent36, s1\_.surcharge AS surcharge37, s1\_.surchargestring AS surchargestring38, s1\_.position AS position39, s1\_.active AS active40, s1\_.esdactive AS esdactive41, s1\_.embediframe AS embediframe42, s1\_.hideprospect AS hideprospect43, s1\_.action AS action44, s1\_.pluginID AS pluginID45, s1\_.source AS source46, s2\_.id AS id47, s2\_.description AS description48, s2\_.position AS position49, s2\_.`group` AS group50, s2\_.mail AS mail51, s3\_.id AS id52, s3\_.description AS description53, s3\_.position AS position54, s3\_.`group` AS group55, s3\_.mail AS mail56, s4\_.id AS id57, s4\_.orderID AS orderID58, s4\_.userID AS userID59, s4\_.countryID AS countryID60, s4\_.company AS company61, s4\_.department AS department62, s4\_.salutation AS salutation63, s4\_.customernumber AS customernumber64, s4\_.firstname AS firstname65, s4\_.lastname AS lastname66, s4\_.street AS street67, s4\_.streetnumber AS streetnumber68, s4\_.zipcode AS zipcode69, s4\_.city AS city70, s4\_.phone AS phone71, s4\_.fax AS fax72, s4\_.ustid AS ustid73, s5\_.id AS id74, s5\_.paymentID AS paymentID75, s5\_.customergroup AS customergroup76, s5\_.subshopID AS subshopID77, s5\_.pricegroupID AS pricegroupID78, s5\_.encoder AS encoder79, s5\_.password AS password80, s5\_.active AS active81, s5\_.email AS email82, s5\_.firstlogin AS firstlogin83, s5\_.lastlogin AS lastlogin84, s5\_.accountmode AS accountmode85, s5\_.confirmationkey AS confirmationkey86, s5\_.sessionID AS sessionID87, s5\_.newsletter AS newsletter88, s5\_.validation AS validation89, s5\_.affiliate AS affiliate90, s5\_.paymentpreset AS paymentpreset91, s5\_.language AS language92, s5\_.referer AS referer93, s5\_.internalcomment AS internalcomment94, s5\_.failedlogins AS failedlogins95, s5\_.lockedUntil AS lockedUntil96, s6\_.id AS id97, s6\_.orderID AS orderID98, s6\_.articleID AS articleID99, s6\_.taxID AS taxID100, s6\_.tax\_rate AS tax\_rate101, s6\_.status AS status102, s6\_.ordernumber AS ordernumber103, s6\_.articleordernumber AS articleordernumber104, s6\_.price AS price105, s6\_.quantity AS quantity106, s6\_.name AS name107, s6\_.shipped AS shipped108, s6\_.shippedgroup AS shippedgroup109, s6\_.releasedate AS releasedate110, s6\_.modus AS modus111, s6\_.esdarticle AS esdarticle112, s6\_.config AS config113, s6\_.ean AS ean114, s6\_.unit AS unit115, s6\_.pack\_unit AS pack\_unit116, s7\_.id AS id117, s7\_.countryname AS countryname118, s7\_.countryiso AS countryiso119, s7\_.countryen AS countryen120, s7\_.position AS position121, s7\_.notice AS notice122, s7\_.shippingfree AS shippingfree123, s7\_.taxfree AS taxfree124, s7\_.taxfree\_ustid AS taxfree\_ustid125, s7\_.taxfree\_ustid\_checked AS taxfree\_ustid\_checked126, s7\_.active AS active127, s7\_.iso3 AS iso3128, s7\_.display\_state\_in\_registration AS display\_state\_in\_registration129, s7\_.force\_state\_in\_registration AS force\_state\_in\_registration130, s7\_.areaID AS areaID131, s8\_.id AS id132, s8\_.main\_id AS main\_id133, s8\_.category\_id AS category\_id134, s8\_.name AS name135, s8\_.title AS title136, s8\_.position AS position137, s8\_.host AS host138, s8\_.base\_path AS base\_path139, s8\_.base\_url AS base\_url140, s8\_.hosts AS hosts141, s8\_.secure AS secure142, s8\_.always\_secure AS always\_secure143, s8\_.secure\_host AS secure\_host144, s8\_.secure\_base\_path AS secure\_base\_path145, s8\_.`default` AS default146, s8\_.active AS active147, s8\_.customer\_scope AS customer\_scope148, s9\_.id AS id149, s9\_.name AS name150, s9\_.type AS type151, s9\_.description AS description152, s9\_.comment AS comment153, s9\_.active AS active154, s9\_.position AS position155, s9\_.calculation AS calculation156, s9\_.surcharge\_calculation AS surcharge\_calculation157, s9\_.tax\_calculation AS tax\_calculation158, s9\_.shippingfree AS shippingfree159, s9\_.multishopID AS multishopID160, s9\_.customergroupID AS customergroupID161, s9\_.bind\_shippingFree AS bind\_shippingFree162, s9\_.bind\_time\_from AS bind\_time\_from163, s9\_.bind\_time\_to AS bind\_time\_to164, s9\_.bind\_instock AS bind\_instock165, s9\_.bind\_laststock AS bind\_laststock166, s9\_.bind\_weekday\_from AS bind\_weekday\_from167, s9\_.bind\_weekday\_to AS bind\_weekday\_to168, s9\_.bind\_weight\_from AS bind\_weight\_from169, s9\_.bind\_weight\_to AS bind\_weight\_to170, s9\_.bind\_price\_from AS bind\_price\_from171, s9\_.bind\_price\_to AS bind\_price\_to172, s9\_.bind\_sql AS bind\_sql173, s9\_.status\_link AS status\_link174, s9\_.calculation\_sql AS calculation\_sql175, s10\_.id AS id176, s10\_.billingID AS billingID177, s10\_.text1 AS text1178, s10\_.text2 AS text2179, s10\_.text3 AS text3180, s10\_.text4 AS text4181, s10\_.text5 AS text5182, s10\_.text6 AS text6183, s11\_.id AS id184, s11\_.orderID AS orderID185, s11\_.attribute1 AS attribute1186, s11\_.attribute2 AS attribute2187, s11\_.attribute3 AS attribute3188, s11\_.attribute4 AS attribute4189, s11\_.attribute5 AS attribute5190, s11\_.attribute6 AS attribute6191, s11\_.swag\_payal\_billing\_agreement\_id AS swag\_payal\_billing\_agreement\_id192, s11\_.mopt\_payone\_txid AS mopt\_payone\_txid193, s11\_.mopt\_payone\_status AS mopt\_payone\_status194, s11\_.mopt\_payone\_sequencenumber AS mopt\_payone\_sequencenumber195, s11\_.mopt\_payone\_is\_authorized AS mopt\_payone\_is\_authorized196, s11\_.mopt\_payone\_is\_finally\_captured AS mopt\_payone\_is\_finally\_captured197, s11\_.mopt\_payone\_clearing\_data AS mopt\_payone\_clearing\_data198, s11\_.swag\_payal\_express AS swag\_payal\_express199, s11\_.swag\_billsafe\_iban AS swag\_billsafe\_iban200, s11\_.swag\_billsafe\_bic AS swag\_billsafe\_bic201, s11\_.bepado\_shop\_id AS bepado\_shop\_id202, s11\_.bepado\_order\_id AS bepado\_order\_id203, s11\_.mopt\_payone\_ship\_captured AS mopt\_payone\_ship\_captured204, s11\_.mopt\_payone\_ship\_debit AS mopt\_payone\_ship\_debit205, s11\_.mopt\_payone\_payment\_data AS mopt\_payone\_payment\_data206 FROM s\_order s0\_ LEFT JOIN s\_core\_paymentmeans s1\_ ON s0\_.paymentID = s1\_.id LEFT JOIN s\_core\_states s2\_ ON s0\_.cleared = s2\_.id LEFT JOIN s\_core\_states s3\_ ON s0\_.status = s3\_.id LEFT JOIN s\_order\_billingaddress s4\_ ON s0\_.id = s4\_.orderID LEFT JOIN s\_user s5\_ ON s0\_.userID = s5\_.id LEFT JOIN s\_order\_details s6\_ ON s0\_.id = s6\_.orderID LEFT JOIN s\_core\_countries s7\_ ON s4\_.countryID = s7\_.id LEFT JOIN s\_core\_shops s8\_ ON s0\_.subshopID = s8\_.id LEFT JOIN s\_premium\_dispatch s9\_ ON s0\_.dispatchID = s9\_.id LEFT JOIN s\_order\_billingaddress\_attributes s10\_ ON s4\_.id = s10\_.billingID LEFT JOIN s\_order\_attributes s11\_ ON s0\_.id = s11\_.orderID WHERE s0\_.status NOT IN ('-1') AND s0\_.ordernumber IS NOT NULL AND s0\_.id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) ORDER BY s0\_.ordertime DESC' with params ["4295", "4291", "4289", "4282", "4280", "4274", "4268", "4266", "4264", "4258", "4254", "4251", "4247", "4241", "4236", "4234", "4231", "4228", "4225", "4223"]: SQLSTATE[42S22]: Column not found: 1054 Unknown column 's6\_.ean' in 'field list'' in /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php:91 Stack trace: #0 /pfad/zum/wwwroot/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(701): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(PDOException), 'SELECT s0\_.id A...', Array) #1 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection-\>executeQuery('SELECT s0\_.id A...', Array, Array, NULL) #2 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor-\>execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query-\>\_doExecute() #4 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(574): Doctrine\ORM\AbstractQuery-\>execute(NULL, 2) #5 /pfad/zum/wwwroot/doctrine/orm/lib/Doctrine/ORM/Tools/Pagination/Paginator.php(186): Doctrine\ORM\AbstractQuery-\>getResult(2) #6 /pfad/zum/wwwroot/engine/Shopware/Controllers/Backend/Order.php(363): Doctrine\ORM\Tools\Pagination\Paginator-\>getIterator() #7 /pfad/zum/wwwroot/engine/Shopware/Controllers/Backend/Order.php(333): Shopware\_Controllers\_Backend\_Order-\>getList(NULL, NULL, '0', '20') #8 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Backend\_Order-\>getListAction() #9 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('getListAction') #10 /pfad/zum/wwwroot/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #11 /pfad/zum/wwwroot/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #12 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #13 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #14 /pfad/zum/wwwroot/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(243): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #15 /pfad/zum/wwwroot/engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #16 /pfad/zum/wwwroot/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #17 {main} [] {"uid":"2e6f111"} Wo kann ich die fehlende Column ‘s0_.plugin_id’ hinzufügen? Oder woran kann das sonst noch liegen? Habe bereits versucht module zu deaktivieren und nach und nach wieder dazu zu nehmen, aber das hat auch nichts gebracht. Shopware 4.3.2 CE Build Rev 201409241139 Jemand eine Idee?
Vielen Dank!
Hi, das sieht ähnlich aus wie bei mir und zwei weiteren Usern. Auch bei mir kam auf mal eine Fehlermeldung direkt nach dem Login im Backend + die Bestellungen lassen sich nicht öffnen. Ansonsten funktioniert aber alles. Auch das Frontend funktioniert + es können Bestellungen getätigt werden. Bei mir fing das bereits gestern an unter der Version 4.3.2. Ich habe heute dann auf die aktuelle Version 4.3.3 geupdatet, in der Hoffnung den Fehler so evtl. zu behben, leider aber ohne Erfolg. Von mir wurden in der letztebn Zeit einige Plugins geupdatet, sodass ich eigentlich davon ausgehe dass es an irgendeinem Plugin liegt. Wobei aber direkt nach den Updates noch alles lief und ich auch zwischenzeitlich alle Plugins deaktiviert hatte + Cache gelöscht, aber auch leider ohne Eerfolg. Ich gehe schon davon aus dass hier ein Plugin komplet etwas überschrieben hat und somit ein einfaches deaktivieren des Plugins nicht mehr hilft, bin mirt aber nicht sicher. Hast Du zufällig auch Plugins geupdatet? Wenn ja welche? Evtl. findet man hier Gemeinsamkeiten und kann das ganze weiter eingrenzen. Es ist schon komisch dass wir mittlerweile schon zu viert sind jetzt die das Problem haben, muss ja irgendwo herkommen. Wie gesat gibt hier gerade 3 Threads bzw. mit deinem jetzt 4 die ungefähr alle das selbe behandeln. Daher schlage ich vor das wir das alles auf einen Thread auslagern. Im folgenden Thread hat sich bereits ein Shopware Mitarbeiter gemeldet dem ich auch schon Zugangsdaten von mir mitgeteilt habe evtl. kommt ja etwas dabei rum, dann würde ich es auch gleich in dem Thread schreiben.
