Kassenbericht lässt sich nicht anzeigen - SQLSTATE[HY093]
Wann immer ich einen bestimmten Eintrag im Kassenbericht-Modul versuche zu öffnen oder als PDF anzuzeigen erscheint untenstehende Fehlermeldung. Andere Berichte hingegen machen keine Probleme. Woran kann das liegen?
SQLSTATE[HY093]: Invalid parameter number: parameter was not defined in engine/Library/Zend/Db/Statement/Pdo.php on line 234
Stack trace:
#0 engine/Library/Zend/Db/Statement.php(303): Zend_Db_Statement_Pdo->_execute(Array)
#1 engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend_Db_Statement->execute(Array)
#2 engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query('SELECT\n ...', Array)
#3 engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(96): Zend_Db_Adapter_Pdo_Abstract->query('SELECT\n ...', Array)
#4 engine/Library/Zend/Db/Adapter/Abstract.php(737): Enlight_Components_Db_Adapter_Pdo_Mysql->query('SELECT\n ...', Array)
#5 engine/Shopware/Plugins/Community/Core/ViisonPickwarePOS/Controllers/Backend/ViisonPickwarePOSDailyClosing.php(590): Zend_Db_Adapter_Abstract->fetchAll()
#6 engine/Shopware/Plugins/Community/Core/ViisonPickwarePOS/Controllers/Backend/ViisonPickwarePOSDailyClosing.php(267): Shopware_Controllers_Backend_ViisonPickwarePOSDailyClosing->getReportTransactions()
#7 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_ViisonPickwarePOSDailyClosing->exportAction()
#8 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('exportAction')
#9 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#10 engine/Shopware/Kernel.php(180): Enlight_Controller_Front->dispatch()
#11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#14 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#15 shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#16 {main}
Hallo MarkusTn,
vielen Dank für deine Nachricht!
Wir würden dich darum bitten uns direkt per E-Mail zu kontaktieren, damit wir uns das Problem in deinem Shop ansehen können. Sobald wir von dir hören kümmern wir uns um den Fehler und finden hier auch sicher eine Lösung.
das Pickware Team
Hallo VIISON,
vielen Dank für die rasche Bearbeitung! Nachdem ich das Thema per eMail an support@pickware.de eingereicht hatte war es innerhalb von ca. 24 Stunden erledigt.
Zur Info: Laut dem Pickware Support handelte es sich wirklich um ein Problem des Plugins _(aktuell Version 3.2.26) _und wurde im betroffenen Shop manuell behoben. Mit dem nächsten Update des Plugins wird dieses Problem im allgemeinen behoben sein.
Somit ist nun alles in Ordnung und funktioniert einwandfrei.
Gruß, Markus
