Habe einige Einstellungen am Shop vorgenommen, geschaut wie alles aussieht. Als ich den Warenkorb oder den Merkzettel angeklickt habe, kam folgende Fehlermeldung: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. An exception occurred while executing ‘SELECT s0_.id AS id0, s0_.userID AS userID1, s0_.paymill_client_id AS paymill_client_id2, s0_.paymill_payment_id_cc AS paymill_payment_id_cc3, s0_.paymill_payment_id_elv AS paymill_payment_id_elv4, s0_.exc_last_transaction_time AS exc_last_transaction_time5, s0_.exc_last_transaction_transaction_id AS exc_last_transaction_transaction_id6, s0_.exc_escore_temporary AS exc_escore_temporary7, s0_.exc_escore AS exc_escore8, s0_.exc_escoreValue AS exc_escoreValue9, s0_.exc_escoreFeature AS exc_escoreFeature10, s0_.exc_lastCheckData AS exc_lastCheckData11 FROM s_user_attributes s0_ WHERE s0_.userID = ? LIMIT 1 OFFSET 0’ with params [“1”]: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘s0_.exc_last_transaction_time’ in ‘field list’ in vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php on line 91 Stack trace: #0 vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(701): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(PDOException), ‘SELECT s0_.id A…’, Array) #1 vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection->executeQuery(‘SELECT s0_.id A…’, Array, Array, NULL) #2 vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(286): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array) #3 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(794): Doctrine\ORM\Query->_doExecute() #4 vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(612): Doctrine\ORM\AbstractQuery->execute(NULL, 2) #5 engine/core/class/sAdmin.php(2434): Doctrine\ORM\AbstractQuery->getOneOrNullResult(2) #6 engine/core/class/sAdmin.php(2312): sAdmin->getUserAttributes(‘1’) #7 Shopware/Controllers/Frontend/Checkout.php(483): sAdmin->sGetUserData() #8 Shopware/Controllers/Frontend/Checkout.php(73): Shopware_Controllers_Frontend_Checkout->getUserData() #9 Enlight/Controller/Action.php(150): Shopware_Controllers_Frontend_Checkout->preDispatch() #10 Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘cartAction’) #11 Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #12 Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #13 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #15 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #16 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #17 Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #18 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #19 Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #20 shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #21 {main} Kann mir jemand helfen, wie man das wieder zum Funktionieren bringt? Bin totaler Laie auf diesem Gebiet. Danke P.S. Habe es eben mal über Chrome geöffnet, alles okay. ich habe heute eine eigene Kundendatei angelegt und wenn ich mich versuche einzuloggen, kommen im Merkzettel und im Warenkorb diese Meldungen:shock:
Irgendein Plugin hat die Spalte exc_last_transaction_time angelegt, die jetzt nicht mehr gefunden werden kann. Meist hilft es, das betroffenen Plugin zu reinstallieren. Schönen Gruß, Daniel
Gibt es eine Möglichkeit direkt irgendwie nach diesem Plugin zu suchen?
