Kann keine Einkaufswelt mehr erstellen bzw aufrufen...
Kann da jemand zufällig etwas damit anfangen…!?
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Entity of type 'Shopware\Models\Shop\Shop' for IDs id(0) was not found in vendor/doctrine/orm/lib/Doctrine/ORM/EntityNotFoundException.php on line 47 Stack trace: #0 vendor/doctrine/orm/lib/Doctrine/ORM/Proxy/ProxyFactory.php(164): Doctrine\ORM\EntityNotFoundException::fromClassNameAndIdentifier('Shopware\\Models...', Array) #1 var/cache/production_202003031106/doctrine/proxies/ __CG__ ShopwareModelsShopShop.php(527): Doctrine\ORM\Proxy\ProxyFactory->Doctrine\ORM\Proxy\{closure}(Object(Shopware\Proxies\ __CG__ \Shopware\Models\Shop\Shop), 'getMain', Array) #2 var/cache/production_202003031106/doctrine/proxies/ __CG__ ShopwareModelsShopShop.php(527): Closure->__invoke(Object(Shopware\Proxies\__CG__\Shopware\Models\Shop\Shop), 'getMain', Array) #3 engine/Shopware/Components/Config.php(300): Shopware\Proxies\__CG__\Shopware\Models\Shop\Shop->getMain() #4 engine/Shopware/Components/Config.php(247): Shopware_Components_Config->readData() #5 engine/Shopware/Components/Config.php(139): Shopware_Components_Config->load() #6 engine/Shopware/Components/DependencyInjection/Bridge/Router.php(81): Shopware_Components_Config->setShop(Object(Shopware\Proxies\__CG__\Shopware\Models\Shop\Shop)) #7 engine/Library/Enlight/Event/Handler/Default.php(87): Shopware\Components\DependencyInjection\Bridge\Router->onAfterRegisterShop(Object(Enlight_Event_EventArgs)) #8 engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute(Object(Enlight_Event_EventArgs)) #9 engine/Shopware/Components/DependencyInjection/Container.php(61): Enlight_Event_EventManager->notify('Enlight_Bootstr...', Object(Enlight_Event_EventArgs)) #10 engine/Shopware/Components/ShopRegistrationService.php(52): Shopware\Components\DependencyInjection\Container->set('shop', Object(Shopware\Proxies\__CG__\Shopware\Models\Shop\Shop)) #11 engine/Shopware/Components/ShopRegistrationService.php(46): Shopware\Components\ShopRegistrationService->registerResources(Object(Shopware\Proxies\__CG__\Shopware\Models\Shop\Shop)) #12 engine/Shopware/Controllers/Backend/Emotion.php(1567): Shopware\Components\ShopRegistrationService->registerShop(Object(Shopware\Proxies\__CG__\Shopware\Models\Shop\Shop)) #13 engine/Shopware/Controllers/Backend/Emotion.php(242): Shopware_Controllers_Backend_Emotion->getSeoUrlFromRouter(4, 1) #14 engine/Library/Enlight/Controller/Action.php(192): Shopware_Controllers_Backend_Emotion->detailAction() #15 engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch('detailAction') #16 engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #17 engine/Shopware/Kernel.php(188): Enlight_Controller_Front->dispatch() #18 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #19 vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true) #20 engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #21 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #22 engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #23 shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #24 {main}
ok, hat sich erledigt…, habs selber herausgefunden…
In Grundeinstellungen > Shopeinstellungen > Shops stand es bei Position noch auf 0…
Mit 1 funzt es jetzt…
