Wenn wir die Standarddaten bei 13.000 Varianten übernehmen erhalten wir die Fehlermeldung "0 - communication failure"
Unser Hostingpaket sollte mit der Anzahl der Varianten eigentlich kein Problem
haben, oder ?
Managed Server Business von Profihost:
4 CPU Kerne Intel Xeon
8 GB RAM - Limitierung auf 2GB
Haben wir möglicherweise zu wenig verfügbaren Arbeitspeicher?
Beste Grüße,
Alexander H.
htaccess
RewriteEngine On
#RewriteBase /shopware/
# Https config for the backend
#RewriteCond %{HTTPS} !=on
#RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteRule backend/media/(.*) media/$1 [NC,L]
RewriteCond %{REQUEST_URI} !(\/(engine|files|templates|themes|web)\/)
RewriteCond %{REQUEST_URI} !(\/media\/(archive|banner|image|music|pdf|unknown|video)\/)
RewriteRule ^(.*)$ shopware.php [PT,L,QSA]
# Fix missing authorization-header on fast_cgi installations
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# Block access to VCS directories
RedirectMatch 404 /\\.(svn|git|hg|bzr|cvs)(/|$)
# Restrict access to root folder files
RedirectMatch 404 /(composer\.(json|lock)|README\.md|UPGRADE\.md)$
# Staging environment
#SetEnvIf Host "staging.test.shopware.in" SHOPWARE_ENV=staging
# Development environment
#SetEnvIf Host "dev.shopware.in" SHOPWARE_ENV=dev
#SetEnv SHOPWARE_ENV dev
DirectoryIndex index.html
DirectoryIndex index.php
DirectoryIndex shopware.php
# Disables download of configuration
# Deny all requests from Apache 2.4+.
Require all denied
# Deny all requests from Apache 2.0-2.2.
Deny from all
# Enable gzip compression
AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/javascript application/json
ExpiresActive on
ExpiresDefault "access plus 1 month"
Header append Cache-Control "public"
Header unset ETag
FileETag None
# Match generated files like:
# 1429684458_t22_s1.css
# 1429684458_t22_s1.js
Header set Cache-Control "max-age=31536000, public"
ExpiresActive on
ExpiresDefault "access plus 1 year"
# Disables auto directory index
Options -Indexes
Options -MultiViews
# php_value memory_limit 256M
# php_value max_execution_time 120
# php_value upload_max_filesize 20M
php_flag phar.readonly off
php_flag magic_quotes_gpc off
php_flag session.auto_start off
php_flag suhosin.session.cryptua off
php_flag zend.ze1_compatibility_mode off
# AddType x-mapp-php5 .php
# AddHandler x-mapp-php5 .php
Header append X-Frame-Options SAMEORIGIN
php5.6.ini
upload_max_filesize = 20M
display_errors = Off
magic_quotes_gpc = Off
memory_limit = 8192M
extension_dir="/usr/local/php_extensions/php5.6/"
extension="apcu.so"
[Zend]
zend_extension=/usr/local/php_extensions/php5.6/ioncube.so
zend_extension=/usr/local/php_extensions/php5.6/opcache.so
opcache.memory_consumption=128
opcache.max_accelerated_files=10000
opcache.max_wasted_percentage=10
