Fehler auf Kategorieseiten und Shop
Hallo, ich bekomme seit heute Fehlermeldungen auf den Kategorieseiten und der Shopseite. SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ’ a.id DESC LIMIT 0, 24’ at line 125 in Zend/Db/Statement/Pdo.php on line 234 Habe schon ForeignKeys repariert, Cache gelöscht. Bin für jeden Hinweis dankbar. Log: [2014-10-09 10:44:49] core.ERROR: exception 'Enlight\_Controller\_Exception' with message 'Action "Frontend\_Blog\_cliccNewsAction" not found failure' in /mnt/web3/d2/81/53409181/htdocs/shop/engine/Library/Enlight/Controller/Action.php:389 Stack trace: #0 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Library/Enlight/Controller/Action.php(159): Enlight\_Controller\_Action-\>\_\_call('cliccNewsAction', Array) #1 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Library/Enlight/Controller/Action.php(159): Shopware\_Proxies\_ShopwareControllersFrontendBlogProxy-\>cliccNewsAction() #2 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('cliccNewsAction') #3 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #4 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #5 /mnt/web3/d2/81/53409181/htdocs/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #6 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #7 /mnt/web3/d2/81/53409181/htdocs/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #8 /mnt/web3/d2/81/53409181/htdocs/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #9 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /mnt/web3/d2/81/53409181/htdocs/shop/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /mnt/web3/d2/81/53409181/htdocs/shop/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /mnt/web3/d2/81/53409181/htdocs/shop/shopware.php(109): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main} [] {"uid":"856ddc5"}
