Hallo liebe Gemeinde ich bekomme jeden Tag 3 Emails mit folgenden Fehler: [2014-04-06 15:22:56] core.ERROR: exception 'Enlight\_Exception' with message 'Template was not loaded failure' in /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/View/Default.php:97 Stack trace: #0 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Plugins/Community/Frontend/PaymPaymentCreditcard/Bootstrap.php(158): Enlight\_View\_Default-\>Template() #1 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware\_Plugins\_Frontend\_PaymPaymentCreditcard\_Bootstrap-\>onCheckoutConfirm(Object(Enlight\_Controller\_ActionEventArgs)) #2 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Plugin-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #3 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Controller/Action.php(192): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #4 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('addArticleActio...') #5 /var/www/KD01/htdocs/dildo-discount.com/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #6 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #7 /var/www/KD01/htdocs/dildo-discount.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #8 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #9 /var/www/KD01/htdocs/dildo-discount.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #10 /var/www/KD01/htdocs/dildo-discount.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>fetch(Object(Symfony\Component\HttpFoundation\Request), true) #11 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #12 /var/www/KD01/htdocs/dildo-discount.com/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache-\>lookup(Object(Symfony\Component\HttpFoundation\Request), true) #13 /var/www/KD01/htdocs/dildo-discount.com/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 /var/www/KD01/htdocs/dildo-discount.com/shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #15 {main} ... Wo kann der Fehler sein? Ich benutze das Standard Template “_emotion_pink”. LG aus Berlin
Kann mir keiner Helfen warum ich ständig den Fehler bekomme? LG Mirko
Hi, schau mal hier: administration-f55/shopware-error-enlight-controller-exception-t19653.html Gruß Patrick Schücker
