Hallo bekomme vom Shop diese E-Mail: [2014-03-01 16:16:20] core.ERROR: exception 'SmartyException' with message 'Unable to load template snippet 'widgets/error/service.tpl'' in /var/www/MA01/htdocs/minalo.de/engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php:127 Stack trace: #0 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/View/Default.php(273): Smarty\_Internal\_TemplateBase-\>fetch() #1 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default)) #2 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default)) #3 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render() #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs)) #5 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs)) #6 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #7 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #8 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('serviceAction') #9 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 /var/www/MA01/htdocs/minalo.de/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #11 /var/www/MA01/htdocs/minalo.de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /var/www/MA01/htdocs/minalo.de/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 /var/www/MA01/htdocs/minalo.de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 /var/www/MA01/htdocs/minalo.de/engine/Shopware/Components/HttpCache/AppCache.php(106): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 /var/www/MA01/htdocs/minalo.de/shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #16 {main} [] [] Der Shop 4.2.1 wurde erst neu Installiert auf einem neuen Server. Was ist das für eine Meldung? Und was muss ich machen? Lg Manu
Ersetze mal in folgender Datei engine/Shopware/Plugins/Default/Core/ErrorHandler/Bootstrap.php die Zeile 261 $mailer-\>setSubject('Error in shop "'.Shopware()-\>Config()-\>Shopname.'".'); durch $mailer-\>setSubject('Error in shop ('.$\_SERVER['REQUEST\_URI'].') "'.Shopware()-\>Config()-\>Shopname.'".'); Damit solltest Du bei der nächsten E-Mail den Link erhalten wo der Fehler aufgetaucht ist. Dann kommst Du dem Fehler ein großen Schritt näher. Gruß
hi kommte leider gleiche meldung: [2014-03-02 16:43:11] core.ERROR: exception 'SmartyException' with message 'Unable to load template snippet 'widgets/error/service.tpl'' in /var/www/MA01/htdocs/minalo.de/engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php:127 Stack trace: #0 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/View/Default.php(273): Smarty\_Internal\_TemplateBase-\>fetch() #1 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default)) #2 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default)) #3 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render() #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs)) #5 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs)) #6 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #7 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #8 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('serviceAction') #9 /var/www/MA01/htdocs/minalo.de/engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 /var/www/MA01/htdocs/minalo.de/engine/Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #11 /var/www/MA01/htdocs/minalo.de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /var/www/MA01/htdocs/minalo.de/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 /var/www/MA01/htdocs/minalo.de/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 /var/www/MA01/htdocs/minalo.de/engine/Shopware/Components/HttpCache/AppCache.php(106): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 /var/www/MA01/htdocs/minalo.de/shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #16 {main} [] [] lg manu
Doch der Betreff ist jetzt neu: Error in shop (/widgets/index/refreshStatistic?requestPage=/&requestController=error&session-1=4ec78d9770f7efdf322b9422fe7fd430ab75cb17&callback=jQuery17209670755068721467_1393777164543&_=1393777164625) “MINALO | Versandhandel”. Und was bedeutet dies nun?
[quote=“MApro”]Doch der Betreff ist jetzt neu: Error in shop (/widgets/index/refreshStatistic?requestPage=/&requestController=error&session-1=4ec78d9770f7efdf322b9422fe7fd430ab75cb17&callback=jQuery17209670755068721467_1393777164543&_=1393777164625) “MINALO | Versandhandel”. Und was bedeutet dies nun?[/quote] Was passiert wenn Du den Link nun aufrufst? Also domain.tld/widgets/…?? Gruß
dann kommt diese meldung: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Unable to load template snippet 'widgets/error/service.tpl' in Smarty/sysplugins/smarty\_internal\_templatebase.php on line 127 Stack trace: #0 Enlight/View/Default.php(273): Smarty\_Internal\_TemplateBase-\>fetch() #1 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default)) #2 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default)) #3 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render() #4 [internal function]: Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs)) #5 Enlight/Event/Handler/Default.php(91): call\_user\_func(Array, Object(Enlight\_Controller\_ActionEventArgs)) #6 Enlight/Event/EventManager.php(211): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs)) #7 Enlight/Controller/Action.php(202): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs)) #8 Enlight/Controller/Dispatcher/Default.php(528): Enlight\_Controller\_Action-\>dispatch('serviceAction') #9 Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #10 Shopware/Kernel.php(141): Enlight\_Controller\_Front-\>dispatch() #11 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(244): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 Shopware/Components/HttpCache/AppCache.php(106): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #15 shopware.php(91): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #16 {main}
Der Fehler liegt beim Aufruf des Index Widgets mit der Action refreshStatistic. Probiere mal in dem Verzeichnis _default/widgets/index/error eine leere Datei mit dem Namen service.tpl anzulegen und ruf den Link erneut auf. Gruß
