Hallo.Nach änderung der Template kam die folgende Fehlermeldung. [quote]Unable to load template extends ‚index/index_home.tpl‘ in Vendor/Smarty/libs/sysplugins/smarty_internal_template.php on line 174 Stack trace: #0 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(551): Smarty_Internal_Template->isExisting(true) #1 Vendor/Smarty/libs/Smarty.class.php(328): Smarty_Internal_Template->getRenderedTemplate() #2 Vendor/Smarty/libs/sysplugins/smarty_internal_template.php(865): Smarty->fetch(Object(Enlight_Template_Template)) #3 Enlight/View/ViewDefault.php(160): Smarty_Internal_Template->fetch() #4 Shopware/Plugins/Default/Frontend/ViewportDispatcher/Bootstrap.php(143): Enlight_View_ViewDefault->fetch(‚index/index_hom…‘) #5 Enlight/Event/EventHandler.php(60): Shopware_Plugins_Frontend_ViewportDispatcher_Bootstrap->onPostDispatchHome(Object(Enlight_Event_EventArgs)) #6 Enlight/Event/EventManager.php(70): Enlight_Event_EventHandler->execute(Array, Object(Enlight_Event_EventArgs)) #7 Enlight/Controller/Action.php(62): Enlight_Event_EventManager->notify(Object(Enlight_Event_EventArgs)) #8 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‚Enlight_Control…‘, Array) #9 Enlight/Controller/Front.php(88): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(‚indexAction‘) #10 Shopware/Bootstrap.php(21): Enlight_Controller_Front->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #11 Enlight/Application.php(69): Shopware_Bootstrap->run() #12 shopware.php(6): Enlight_Application->run() #13 {main}[/quote] Und jetzt weis ich nicht mehr weiter. Kann mir da jemand weiterhelfen ?. Vielen Dank im Vorraus.
