Hallo Community, wenn ich die Schritte dieser Anleitung: Your text to link here… befolge, um die TAGWolke von der Stratseite meines Shops (Emotion Blue Theme) zu entfernen, erhalte ich diese Fehlermeldung: Fatal error: Uncaught exception ‘SmartyCompilerException’ with message ‘Syntax Error in template “/58573155f584b668213a0551b5fa2cb2/www/templates/_default/frontend/home/index.tpl” on line 2 “” illegal recursive call of “frontend/index/index.tpl”’ in /58573155f584b668213a0551b5fa2cb2/www/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php:657 Stack trace: #0 /58573155f584b668213a0551b5fa2cb2/www/engine/Library/Smarty/sysplugins/smarty_internal_compile_extends.php(82): Smarty_Internal_TemplateCompilerBase->trigger_template_error(‘illegal recursi…’, 2) #1 /58573155f584b668213a0551b5fa2cb2/www/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(465): Smarty_Internal_Compile_Extends->compile(Array, Object(Smarty_Internal_SmartyTemplateCompiler), Array, NULL, NULL) #2 /58573155f584b668213a0551b5fa2cb2/www/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php(249): Smarty_Internal_TemplateCompilerBase->callTagCompiler(‘extends’, Arra in /58573155f584b668213a0551b5fa2cb2/www/engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php on line 657 Fatal error: Undefined class constant ‘PRIMARY_TYPE_NUM’ in /58573155f584b668213a0551b5fa2cb2/www/engine/Library/Zend/Session/SaveHandler/DbTable.php on line 522 Was ist da passiert? (An der php hab ich nichts verändert!)
