Es funktioniert…teilweise. Jedenfalls bekomme ich jetzt eine Email, dass die Bestellbestätigung nicht gesendet werden konnte.
Folgendes wird mir noch in der Fehlermeldunge - EMail angezeigt:
Channel: core
Context:
"exception": {
"class": "Enlight\_Exception",
"message": "Syntax Error 4c" on line 17 "{/if}" unknown tag "ifclose"",
"code": 0,
"file": "/var/www/web26887759/html/engine/Shopware/Components/StringCompiler.php:177",
"trace": [
"/var/www/web26887759/html/engine/Shopware/Components/StringCompiler.php:148",
"/var/www/web26887759/html/engine/Shopware/Components/TemplateMail.php:233",
"/var/www/web26887759/html/engine/Shopware/Components/TemplateMail.php:192",
"/var/www/web26887759/html/engine/Shopware/Core/sOrder.php:909",
"/var/www/web26887759/html/engine/Shopware/Core/sOrder.php:813",
"/var/www/web26887759/html/engine/Shopware/Controllers/Frontend/Checkout.php:839",
"/var/www/web26887759/html/engine/Shopware/Controllers/Frontend/Checkout.php:372",
"/var/www/web26887759/html/engine/Library/Enlight/Controller/Action.php:159",
"/var/www/web26887759/html/engine/Library/Enlight/Controller/Dispatcher/Default.php:523",
"/var/www/web26887759/html/engine/Library/Enlight/Controller/Front.php:223",
"/var/www/web26887759/html/engine/Shopware/Kernel.php:182",
"/var/www/web26887759/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php:491",
"/var/www/web26887759/html/engine/Shopware/Components/HttpCache/AppCache.php:266",
"/var/www/web26887759/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php:258",
"/var/www/web26887759/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php:275",
"/var/www/web26887759/html/engine/Shopware/Components/HttpCache/AppCache.php:141",
"/var/www/web26887759/html/vendor/symfony/http-kernel/HttpCache/HttpCache.php:206",
"/var/www/web26887759/html/engine/Shopware/Components/HttpCache/AppCache.php:114",
"/var/www/web26887759/html/shopware.php:117"
request:
"uri": "/checkout/finish",
"method": "POST",
"query": {
"module": "frontend",
"controller": "checkout",
"action": "finish"
"post": {
"sComment": "",
"sAGB": "on",
"\_\_csrf\_token": "sCTYOSdMt0opyYTP5jRtjR3UyqqdFH"
session:
No session data available
shopId:
1
Weiß jemand was das bedeutet?
Heiko
