Hallo und guten Morgen, mit dem Plugin Easycoupon gibts ein Problem: [quote] exception ‘Enlight_Exception’ with message ‘Mail-Template with name ‘netiEasyCoupon_conditionAdminMail’ could not be found.’ in /engine/Shopware/Components/TemplateMail.php:152 Stack trace: #0 /engine/Shopware/Plugins/Community/Backend/NetiEasyCoupon/Bootstrap.php(3692): Shopware_Components_TemplateMail->createMail() #1 /engine/Shopware/Plugins/Community/Backend/NetiEasyCoupon/Bootstrap.php(4012): Shopware_Plugins_Backend_NetiEasyCoupon_Bootstrap->sendAdminEventsMail() #2 /engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_NetiEasyCoupon_Bootstrap->beforeMailSend(Object(Enlight_Event_EventArgs)) #3 /engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Event_EventArgs)) #4 /engine/core/class/sOrder.php(1223): Enlight_Event_EventManager->notify(‘Shopware_Module…’, Array) #5 /engine/core/class/sOrder.php(730): sOrder->sendMail(Array) #6 [internal function]: sOrder->sSaveOrder() #7 /cache/proxies/sOrderProxy.php(11): call_user_func_array(Array, Array) #8 /engine/Library/Enlight/Hook/HookManager.php(191): Shopware_Proxies_sOrderProxy->executeParent(‘sSaveOrder’, Array) #9 /cache/proxies/sOrderProxy.php(23): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_sOrderProxy), ‘sSaveOrder’, Array) #10 /engine/Shopware/Controllers/Frontend/Checkout.php(563): Shopware_Proxies_sOrderProxy->sSaveOrder() #11 /engine/Shopware/Controllers/Frontend/Checkout.php(242): Shopware_Controllers_Frontend_Checkout->saveOrder() #12 [internal function]: Shopware_Controllers_Frontend_Checkout->finishAction() #13 /cache/proxies/ShopwareControllersFrontendCheckoutProxy.php(11): call_user_func_array(Array, Array) #14 /engine/Library/Enlight/Hook/HookManager.php(191): Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy->executeParent(‘finishAction’, Array) #15 /cache/proxies/ShopwareControllersFrontendCheckoutProxy.php(23): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy), ‘finishAction’, Array) #16 /engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy->finishAction() #17 /engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘finishAction’) #18 /engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #19 /engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #20 /vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #21 /engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #22 /vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(243): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #23 /vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(260): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #24 /engine/Shopware/Components/HttpCache/AppCache.php(132): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #25 /vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(189): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #26 /engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #27 /shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #28 {main} [/quote] Das ist wahrscheinlich auch der Grund, warum der restl. Mailversand im Shop nicht klappt. Ich bitte hier dringend um eine Lösung. Vielen Dank.
das Problem wurde durch Netinventors schnell erkannt, ein Update des Plugins folgt. Wer das Plugin im Einsatz hat und nicht auf das Update warten will, hier die vorgehensweise: [quote]Mail vom Netinventors - Auszug - Plugin-Einstellungen des Basis-Plugins EasyCoupon notieren - EasyCoupon deinstallieren - EasyCoupon wieder installieren - Plugin-Einstellungen wieder auf die vorherigen Werte zurücksetzen [/quote] Dadurch erledigt sich auch mein generelles Problem mit dem Mailversand (Bestellbestätigung, Statusmails) im Shop!
