DNS records at the provider (hosting) side
I have a domain at a hosting provider. I need to add the correct records for shopware 5.6.10
Can anybody tell me where to find them or put a copy in this topic?
I do not understand your question.
What records for Shopware do you need? If your domain ist controlled by a „third“ provider, you have to set the domain records to your webspace provider. That is independent from Shopware.
Maybe the question is better the other way around. Do I have to set something in the shopware configuration to have it connected tot the new hosting provider?
within Shopware you only define the domain name under which the shop should be reachable. At your provider, you configure the destination IP for the domain in it´s DNS zone settings.
The IP to be defined is the one of the server where your Shopware installation is located.
Regards
