Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. unable to write file /var/www/www.jsg-shop.de/htdocs/cache/templates/compile/frontend_emotion_blue_de_DE_1/a3/27/af/wrt51dbd6bb41c308.36210881 in Smarty/sysplugins/smarty_internal_write_file.php on line 48 Stack trace: #0 Smarty/sysplugins/smarty_internal_template.php(201): Smarty_Internal_Write_File::writeFile(’/var/www/www.js…’, ‘<?php /* Smarty…’, Object(Enlight_Template_Manager))
#1 Smarty/sysplugins/smarty_internal_templatebase.php(164): Smarty_Internal_Template->compileTemplateSource() #2 Enlight/View/Default.php(273): Smarty_Internal_TemplateBase->fetch() #3 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render(Object(Enlight_Template_Default)) #4 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #5 Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #6 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Event_EventArgs)) #7 Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Event_EventArgs)) #8 Enlight/Event/EventManager.php(156): Enlight_Event_Handler_Default->execute(Object(Enlight_Event_EventArgs)) #9 Enlight/Controller/Action.php(147): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Array) #10 Enlight/Controller/Dispatcher/Default.php(521): Enlight_Controller_Action->dispatch(‘indexAction’) #11 Enlight/Controller/Front.php(214): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #12 Shopware/Bootstrap.php(79): Enlight_Controller_Front->dispatch() #13 Enlight/Application.php(192): Shopware_Bootstrap->run() #14 shopware.php(74): Enlight_Application->run() #15 {main} dringend hilfe bitte!!!
Hallo, die Meldung besagt, dass nicht mehr auf die Ordner unter /cache geschrieben werden kann. Entweder besitzen diese nicht mehr ausreichende Rechte, die Ordner sind nicht mehr da oder es steht kein Speicherplatz mehr zur Verfügung. Diese drei Punkte sollten mal im ersten Schritt geprüft werden. Sebastian
