Hi!
Does anybody know how to configure the contact form?
In email templates i assigned the standard form to the corresponding Sales channel. When sending a test email to myself i don’t receive anything.
Furthermore when using the form in the frontend i get an warning that the subject isn’t filled in while it actually is.
Which email does the contact form use to send the emails?
timbrns
2
Hi Dylan,
there are 3 important factors to have a look at:
- you need a mailer up and running in your settings -> system -> mailer (this will get used for the mail)
- you need a template for contact forms in your settings -> shop -> email templatesÂ
- your contact form which is implemented into a shopping experience needs to have a receiver mail (selectable for each contactform indiviudally)
Hope this makes it more clear
Kind regards,
TimÂ
FinnMac
3
Where can you select the receiver mail? We have a contact form that is not sending to the owner of the shop.
