Hallo ich habe wenn im mich einlogge oder wenn ich darin arbeite seid dem ich paar shopware updates gemacht habe immer die fehler Connection failure und das was unten im text steht was kann man da ambesten machen… [2014-02-13 17:50:18] core.ERROR: exception ‘Enlight_Controller_Exception’ with message ‘Action “Widgets_Index_deAction” not found failure’ in /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Action.php:389 Stack trace: #0 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Action.php(159): Enlight_Controller_Action->__call(‘deAction’, Array) #1 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersWidgetsIndexProxy->deAction() #2 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘deAction’) #3 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #4 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #5 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #6 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #7 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #8 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #9 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /home/www/doc/21338/testshop/install_4.0.5/shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main} {“uid”:“8f35508”} [2014-02-13 17:50:48] core.ERROR: exception ‘Enlight_Controller_Exception’ with message ‘Action “Widgets_Index_deAction” not found failure’ in /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Action.php:389 Stack trace: #0 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Action.php(159): Enlight_Controller_Action->__call(‘deAction’, Array) #1 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersWidgetsIndexProxy->deAction() #2 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Dispatcher/Default.php(528): Enlight_Controller_Action->dispatch(‘deAction’) #3 /home/www/doc/21338/testshop/install_4.0.5/engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #4 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #5 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(473): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #6 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #7 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(430): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #8 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(330): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #9 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #10 /home/www/doc/21338/testshop/install_4.0.5/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(194): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #11 /home/www/doc/21338/testshop/install_4.0.5/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /home/www/doc/21338/testshop/install_4.0.5/shopware.php(91): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main} {“uid”:“c8571a5”}
hat echt keiner eine Idee?
Steht immer was von 4.0.5. scheint mir was nicht richtig durchgelaufen zu sein. Altes backup einspielen und dann noch mal die Updates einspielen würde ich versuchen. Sonst musst du mal genauer schreiben was du wie und wann gemacht hast. Sent from my iPad using Tapatalk
das ist nur der pfad wo ich das damals installiert hatte könnte auch nur shopware stehen… also es kommt manchmal alleine wenn ich mich im backend einlogge
