Heyho - ich bekomme immer wieder zufällig Fehler beim Upload. Mal funktioniert der Upload eines Bildes dann wieder nicht. Wenn der Upload nicht funktioniert spukkt mir die Console folgenden Fehler: [code]Failed to load resource: the server responded with a status of 503 (Service Unavailable)Ext.define.uploadFile @ base:2552 ext-all.js:21 Uncaught Ext.JSON.decode(): You’re trying to decode an invalid JSON String:
File not found: media/image/agb.png in Shopware/Components/Thumbnail/Generator/Basic.php on line 75
Stack trace:
#0 Shopware/Components/Thumbnail/Manager.php(150): Shopware\Components\Thumbnail\Generator\Basic-\>createThumbnail('media/image/agb...', '/media/image/th...', 140, 140, true, 90) #1 Shopware/Controllers/Backend/MediaManager.php(593): Shopware\Components\Thumbnail\Manager-\>createMediaThumbnail(Object(Shopware\Models\Media\Media), Array, true) #2 Enlight/Controller/Action.php(158): Shopware\_Controllers\_Backend\_MediaManager-\>uploadAction() #3 Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('uploadAction') #4 Enlight/Controller/Front.php(227): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #5 Shopware/Kernel.php(148): Enlight\_Controller\_Front-\>dispatch() #6 vendor/symfony/http-kernel/HttpCache/HttpCache.php(492): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #7 Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #8 vendor/symfony/http-kernel/HttpCache/HttpCache.php(263): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #9 Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #10 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #11 {main}
http://www.ichbineintest.de/backend/base?file=bootstrap&loggedIn=1447945458 Failed to load resource: the server responded with a status of 503 (Service Unavailable)Ext.define.uploadFile @ base:2552 ext-all.js:21 Uncaught Ext.JSON.decode(): You’re trying to decode an invalid JSON String:
Stack trace:
[/code] Ich kann mir nicht wirklich erklären, woran das liegen kann. Zumal der Upload rein zufällig einmal funktioniert und dann wieder nicht. Hat jemand evtl. dasselbe Problem?
