Weiterleitung zu PayPal funktioniert nicht
aktuell haben wir leider vermehrt Probleme mit der Weiterleitung zur PayPal-Zahlung.
Die Fehlermeldung im Log ist folgende:
Zend_Http_Client_Adapter_Exception: Unable to Connect to ssl://api-3t.paypal.com:443. Error
#110: Connection timed out in /engine/Library/Zend/Http/Client/Adapter/Socket.php:227 Stack trace:
#0 /engine/Library/Zend/Http/Client.php(1041): Zend_Http_Client_Adapter_Socket->connect('ssl://api-3t.pa...', 443, true)
#1 /engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Components/Paypal/Client.php(105): Zend_Http_Client->request('POST')
#2 /engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(183): Shopware_Components_Paypal_Client->__call('SetExpressCheck...', Array)
#3 /engine/Library/Enlight/Controller/Action.php(193): Shopware_Controllers_Frontend_PaymentPaypal->gatewayAction()
#4 /engine/Library/Enlight/Controller/Dispatcher/Default.php(549): Enlight_Controller_Action->dispatch('gatewayAction')
#5 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#6 /engine/Shopware/Kernel.php(215): Enlight_Controller_Front->dispatch()
#7 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(486): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 /engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(443): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(339): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /engine/Shopware/Components/HttpCache/AppCache.php(189): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(205): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#14 /var/www/vhosts/xyz.de/httpdocs/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#15 {main}
Wir können das aktuell noch nicht sicher nachstellen, manchmal funktioniert es, manchmal nicht. cURL wurde testweise deaktiviert.
Für Rückmeldungen wäre ich sehr dankbar.
Beste Grüße,
Octo
PHP Version? PayPal Version?
Um Kompatibilität zu gewährleisten, wird noch das alte Plugin in Version 3.5.0 und PHP 7.4 verwendet. Der Wechsel zu SW6 ist noch nicht abgeschlossen.
Das Plugin „PayPal Express“ wurde nun auf die aktuellste Version 3.7.2 upgedated. Poblem weiterhin vorhanden. Ursache für uns aktuell nicht reproduzierbar, mal klappt es, mal kommt es zum Timeout. PHP-Version ist noch 7.0.33, für die Abwärtskompatibilität.
Funktioniert denn das eigentliche PayPal-Plugin mittlerweile stabil? Gerade am Anfang gab es da ja leider oft Probleme:
Läuft bei mir mit Plugin 6.1.10, SW 5.6.10 und PHP 7.4.33
Eure Plugin-Version ist völlig veraltet. Die aktuelle Version ist 6.1.10 … oder eurer SW5 ist extrem alt, so dass die aktuelle PayPal-Version gar nicht erst angezeigt wird.
