Liebes Forum
ich habe eine eigene Testbestellung mit Paypal gemacht.
Im Warenkorb auf „Direkt mit PayPal bezahlen geklickt“. Dann kam im Frontend die berühmte Fehlermeldung:
Ups, es ist ein Fehler aufgetreten…
Dazu habe ich die Fehle-E-Mail bekommen:
ERROR
Message: exception ‚Zend_Http_Client_Adapter_Exception‘ with message ‚Unable to Connect to ssl://api-3t.paypal.com:443. Error #110: Connection timed out‘ in /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Http/Client/Adapter/Socket.php:235
Stack trace:
#0 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Zend/Http/Client.php(1059): Zend_Http_Client_Adapter_Socket->connect(‚api-3t.paypal.c…‘, 443, true)
#1 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Components/Paypal/Client.php(105): Zend_Http_Client->request(‚POST‘)
#2 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(175): Shopware_Components_Paypal_Client->__call(‚setExpressCheck…‘, Array)
#3 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(175): Shopware_Components_Paypal_Client->setExpressCheckout(Array)
#4 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_PaymentPaypal->gatewayAction()
#5 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚gatewayAction‘)
#6 /var/www/vhosts/meinshop.de/httpdocs/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#7 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#8 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#9 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#10 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(444): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /var/www/vhosts/meinshop.de/httpdocs/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /var/www/vhosts/meinshop.de/httpdocs/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 /var/www/vhosts/meinshop.de/httpdocs/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#16 {main}
Time: 2016-12-01T09:31:24.567016+0100
Channel: core
request: {
„uri“: „/payment_paypal/express“,
„method“: „GET“,
„query“: {
„module“: „frontend“,
„controller“: „payment_paypal“,
„action“: „express“
„post“:
session: No session data available
shopId: 1
shopName: meinshop
In der Fehlerdatei der plugin_production-2016-12-01.log steht dazu nichts.
Ich habe dann einen Reload gemacht, und dann ging es.
Was kann das sein ?
Liebe Grüße
Kerstin
