Problem mit Paypal ?
Seit ein paar Stunden geht Paypal nicht mehr. Folgende Fehlermeldung erhalte ich :
ERROR
Message:
exception 'Zend_Http_Client_Exception' with message 'Error in cURL request: name lookup timed out' in /www/htdocs/w0086***/shop5/engine/Library/Zend/Http/Client/Adapter/Curl.php:426
Stack trace:
#0 /www/htdocs/w0086***/shop5/engine/Library/Zend/Http/Client.php(1073): Zend_Http_Client_Adapter_Curl->write('POST', Object(Zend_Uri_Http), '1.1', Array, 'METHOD=SetExpre...')
#1 /www/htdocs/w0086***/shop5/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Components/Paypal/Client.php(105): Zend_Http_Client->request('POST')
#2 /www/htdocs/w0086***/shop5/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(175): Shopware_Components_Paypal_Client->__call('setExpressCheck...', Array)
#3 /www/htdocs/w0086***/shop5/engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Frontend/PaymentPaypal.php(175): Shopware_Components_Paypal_Client->setExpressCheckout(Array)
#4 /www/htdocs/w0086***/shop5/engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Frontend_PaymentPaypal->gatewayAction()
#5 /www/htdocs/w0086***/shop5/engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('gatewayAction')
#6 /www/htdocs/w0086***/shop5/engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#7 /www/htdocs/w0086***/shop5/engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch()
#8 /www/htdocs/w0086***/shop5/vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#9 /www/htdocs/w0086***/shop5/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#10 /www/htdocs/w0086***/shop5/vendor/symfony/http-kernel/HttpCache/HttpCache.php(444): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /www/htdocs/w0086***/shop5/vendor/symfony/http-kernel/HttpCache/HttpCache.php(344): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /www/htdocs/w0086***/shop5/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#13 /www/htdocs/w0086***/shop5/vendor/symfony/http-kernel/HttpCache/HttpCache.php(210): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /www/htdocs/w0086***/shop5/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 /www/htdocs/w0086***/shop5/shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#16 {main}
Time:
2016-10-21T19:53:41.822130+0200
Channel:
core
request:
    "uri": "/payment_paypal",
    "method": "GET",
    "query": {
        "module": "frontend",
        "controller": "payment_paypal",
        "action": "index"
    "post": []
kann das jemand bestätigen ?
oder habe nur ich da ein Problem ?
Vielen Dank !
Könnte mit der Distributed Denial of Service Attacke auf eBay, Twitter, Spotify, Amazon und Co. zusammenhängen:
Habe das selbe Problem mit PayPal, habe es erstmal als Zahlungsart deaktiviert…
Im Backend sieht die Fehlermeldung dann so aus:
Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. Error in cURL request: SSL peer certificate or SSH remote key was not OK in engine/Library/Zend/Http/Client/Adapter/Curl.php on line 426 Stack trace: #0 engine/Library/Zend/Http/Client.php(1073): Zend_Http_Client_Adapter_Curl->write('POST', Object(Zend_Uri_Http), '1.1', Array, 'METHOD=GetBalan...') #1
engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Components/Paypal/Client.php(105): Zend_Http_Client->request('POST') #2 engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Backend/PaymentPaypal.php(252): Shopware_Components_Paypal_Client->__call('getBalance', Array) #3 engine/Shopware/Plugins/Community/Frontend/SwagPaymentPaypal/Controllers/Backend/PaymentPaypal.php(252): Shopware_Components_Paypal_Client->getBalance(Array) #4 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_PaymentPaypal->getBalanceAction() #5 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch('getBalanceActio...') #6 engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #7 engine/Shopware/Kernel.php(177): Enlight_Controller_Front->dispatch() #8 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #9 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #10 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #11 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true) #12 shopware.php(113): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #13 {main}
Es scheint nun wieder zu gehen, habe gerade im Backend den Zugriff getestet.
bei mir nicht
message: Error in cURL request: Could not resolve host: api-3t.paypal.com
Bei mir geht auch noch nix
Bei mir ebenfalls nicht…
Error in cURL request: Could not resolve host: api-3t.paypal.com in Zend/Http/Client/Adapter/Curl.php on line 426
Hier auch nochmal die Info: http://t3n.de/news/mega-ddos-angriff-totalausfall-758183/
Scheint als gäbe es Probleme mit Paypal aufgrund eines angriffes.
@Moritz Naczenski‍ was echt blöd ist das ist diesen Fall der ganzen Warenkorb lahmgelegt ist. Das muss sich in Zukunft ändern…
Hängt aber auch von der individuellen DNS-Config ab. Bei mir gehen alle aufgelisteten Dienste - inkl. PayPal im Shop.
Wohl dem, desen DNS auf einen Nameserver gehen, der eine höhere lease verwendet.
Willkommen in der schönen neuen Cloudwelt  Wink
Meine Wawi, Exchange (lokal) gehen auch ohne weg-ge-ddos-te Dienste noch
2-3 kunden konnten wieder über PayPal bestellen jetzt hängt der Warenkorb wieder & ich bekomme diese Meldung:
ACK: Success
status: 429
message: Too Many Requests
informationLink: null
Habe ich eben schon ein Ticket zu angelegt: Shopware Issuetracker
