Was ist das für ein Fehler ?
Kann keine Rechnung,Lieferschein mehr generien im backend.
Wer kann helfen,habe die suche schon benutzt!
Syntax Error in template „40db0860177e3317de7d0c0ca395a389b305fb9e“ on line 304 „{mso-style-name:„Normale Tabelle“;“ - Unexpected „:“, expected one of: „}“ , " " , ATTR in engine/Library/Smarty/sysplugins/smarty_internal_templatecompilerbase.php on line 657
Stack trace:
 #0 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3144): Smarty\_Internal\_TemplateCompilerBase-\>trigger\_template\_error() #1 engine/Library/Smarty/sysplugins/smarty\_internal\_templateparser.php(3209): Smarty\_Internal\_Templateparser-\>yy\_syntax\_error(2, ':') #2 engine/Library/Smarty/sysplugins/smarty\_internal\_smartytemplatecompiler.php(105): Smarty\_Internal\_Templateparser-\>doParse(2, ':') #3 engine/Library/Smarty/sysplugins/smarty\_internal\_templatecompilerbase.php(192): Smarty\_Internal\_SmartyTemplateCompiler-\>doCompile('
**Cara...') #4 engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(187): Smarty\_Internal\_TemplateCompilerBase-\>compileTemplate(Object(Enlight\_Template\_Default)) #5 engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(155): Smarty\_Internal\_Template-\>compileTemplateSource() #6 engine/Shopware/Components/Document.php(418): Smarty\_Internal\_TemplateBase-\>fetch('string:
<stro... engine shopware_components_document->loadConfiguration4x()
#8 engine/Shopware/Components/Document.php(233): Shopware_Components_Document-&gt;assignValues()
#9 engine/Shopware/Controllers/Backend/Document.php(67): Shopware_Components_Document-&gt;render()
#10 engine/Library/Enlight/Controller/Action.php(159): Shopware_Controllers_Backend_Document-&gt;indexAction()
#11 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action-&gt;dispatch('indexAction')
#12 engine/Library/Enlight/Controller/Front.php(226): Enlight_Controller_Dispatcher_Default-&gt;dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#13 engine/Shopware/Kernel.php(175): Enlight_Controller_Front-&gt;dispatch()
#14 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-&gt;handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#15 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-&gt;forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-&gt;forward(Object(Symfony\Component\HttpFoundation\Request), true)
#17 engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache-&gt;pass(Object(Symfony\Component\HttpFoundation\Request), true)
#18 shopware.php(101): Shopware\Components\HttpCache\AppCache-&gt;handle(Object(Symfony\Component\HttpFoundation\Request))
#19 {main}</stro...>**
das „mso-style-name“ stammt von dir, oder? Wenn geschweifte Klammern im Template { und } genutzt werden, versucht Smarty das zu parsen. Da es kein valider Smarty-Code ist, gibt es den Fehler. Als Abhilfe entweder Leerzeichen vor / nach den Klammern setzen oder {literal}DEINE ANPASSUNG{/literal} - das geht auch.
Daniel
Nein ist nicht von mir! Habe das Responsive Template drinn.
Doch, ist definitiv von dir. Du hast an irgendeiner Stelle im backend (Konfiguration, Textbausteine etc) copy/paste aus Word genutzt. Leider kopiert Word dabei auch ungültige Metadaten (zb mso-style-name) mit.
Danke für die Antwort, aber wie kann ich das Rückgängig machen ??
Viele grüße
Backup
gibt es auch eine andere möglichkeit , wie z.b Datenbank weil ich nicht mehr weiß wann es geändert wurde.wenn ja wo muss ich suchen.
Hatte einen Schlaganfall.
mfg rolli
http://community.shopware.com/Fehlermeldungen-in-Shopware-debuggen_detail_1880.html
http://community.shopware.com/Debuggen-mit-FirePHP-und-Shopware_detail_571.html
Kann es sein, dass Du irgendwelche Textinhalte aus Outlook, Word o.ä. kopiert hast und verwendest?
" mso" Notationen sind spezifische Microsoft-Auszeichnungen , die bei Copy-Paste (leider) immer mitgenommen werden. Möglicherweise wird ein Text in einem Template nicht korrekt maskiert wodurch der genannte Fehler entsteht. Oder jemand hat den Text direkt ins Template kopiert.
