folgende Fehlermeldung erhalten wir. Jemand eine Idee??? Error Received an error message. URL: unpack?offset=0&total=0 Message: SyntaxError: JSON.parse: unexpected non-whitespace character after JSON data at line 6 column 2 of the JSON data Please try to fix this error and restart the update. Response { “valid”: false, “offset”: 0, “total”: 0, “success”: true } Warning: Unknown: open(/var/lib/php/session/sess_ehfa4mkig087o287regjb4u1f6, O_RDWR) failed: Permission denied (13) in Unknown on line 0 Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/session) in Unknown on line 0
Der Fehler steht ja da Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct Überprüfe die Rechte in /var/lib/php/session/ und überprüfe ob session.save_path korrekt gesetzt ist. Schreibe einmal deinen Hoster an.
