Update 5.5.4 -> 5.5.6 -> Datenbank Update bricht ab, Backend und Frontend nicht erreichbar
Error
Received an error message.
URL: unpack?offset=0&total=0
Message: SyntaxError: JSON.parse: unexpected non-whitespace character after JSON data at line 6 column 2 of the JSON data
Response
    "valid": false,
    "offset": 1209,
    "total": 1209,
    "success": true
Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/knplabs/gaufrette/src/Gaufrette/Util/Path.php on line 31
Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/knplabs/gaufrette/src/Gaufrette/Util/Path.php on line 35
Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /var/www/vhosts/domain.com/httpdocs/recovery/common/vendor/knplabs/gaufrette/src/Gaufrette/Util/Path.php on line 37
1 / 3
Dateien werden überschrieben...
Hilfe!
Php 7.3 im Einsatz ? Falls ja stell mal auf 7.2 um, dann die Seite neu laden und nochmal probieren…
7.3 und nginx waren das Problem…puuuh. Danke für den Hinweis!
