Error
Received an error message.
URL: unpack?offset=0&total=0
Message: SyntaxError: JSON.parse: unexpected non-whitespace character after JSON data at line 6 column 2 of the JSON data
Response
"valid": true,
"offset": 2727,
"total": 8328,
"success": true
Warning: Unknown: open(/var/lib/php5/sessions/sess_7v3dscqmjnj109m67398b3uoe7, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5/sessions) in Unknown on line 0
O.g Fehlermeldung erscheint beim Update von 5.3 auf 5.4. Backend und Frontend sind seither im Wartungsmodus. Hilfe! Danke!
