ich habe meinen Shop gerade auf 5.7.3 geupdatet und musste feststellen, dass ich keine Artikel mehr in den Warenkorb legen kann. Es dreht sich nur der Kreis und nichts passiert. Über die Log habe ich gesehen, dass das Trusted Shops 2.0 Plugin wohl verantwortlich ist. Dort sind folgende Fehler:
[2021-09-27 22:34:03] core.CRITICAL: An exception occurred while executing ‚SELECT * FROM s_crontab c WHERE (c.active = 1) AND (c.end IS NOT NULL) AND (c.next <= ?) ORDER BY c.next ASC‘ with params („2021-09-27 22:34:02“): SQLSTATE(42S02): Base table or view not found: 1146 Table ‚c1w2db1.s_crontab‘ doesn’t exist {„uid“:„03b018f“}
[2021-09-27T22:40:01.960667+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„106f150“}
[2021-09-27T22:40:01.972961+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„106f150“}
[2021-09-27T22:40:01.973773+02:00] core.ERROR: Enlight_Exception: Method „Shopware::Cache“ not found failure in /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php:154 Stack trace: #0 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Components/SoapApi.php(145): Shopware->__call() #1 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php(154): Shopware\SwagTrustedShopsExcellence\Components\SoapApi->checkCertificateTypeIfExcellence() #2 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/Handler/Default.php(90): Shopware\SwagTrustedShopsExcellence\Subscriber\Frontend->onCheckoutPostDispatch() #3 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Default->execute() #4 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Action.php(196): Enlight_Event_EventManager->notify() #5 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(461): Enlight_Controller_Action->dispatch() #6 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Front.php(225): Enlight_Controller_Dispatcher_Default->dispatch() #7 /var/www/clients/client1/web2/web/engine/Shopware/Kernel.php(192): Enlight_Controller_Front->dispatch() #8 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle() #9 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle() #10 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward() #11 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Shopware\Components\HttpCache\AppCache->forward() #12 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(283): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass() #13 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate() #14 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->invalidate() #15 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle() #16 /var/www/clients/client1/web2/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle() #17 {main} {„uid“:„106f150“}
[2021-09-27T22:40:26.840993+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„15ead6e“}
[2021-09-27T22:40:26.847328+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„15ead6e“}
[2021-09-27T22:40:26.848213+02:00] core.ERROR: Enlight_Exception: Method „Shopware::Cache“ not found failure in /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php:154 Stack trace: #0 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Components/SoapApi.php(145): Shopware->__call() #1 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php(154): Shopware\SwagTrustedShopsExcellence\Components\SoapApi->checkCertificateTypeIfExcellence() #2 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/Handler/Default.php(90): Shopware\SwagTrustedShopsExcellence\Subscriber\Frontend->onCheckoutPostDispatch() #3 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Default->execute() #4 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Action.php(196): Enlight_Event_EventManager->notify() #5 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(461): Enlight_Controller_Action->dispatch() #6 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Front.php(225): Enlight_Controller_Dispatcher_Default->dispatch() #7 /var/www/clients/client1/web2/web/engine/Shopware/Kernel.php(192): Enlight_Controller_Front->dispatch() #8 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle() #9 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle() #10 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward() #11 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Shopware\Components\HttpCache\AppCache->forward() #12 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(283): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass() #13 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate() #14 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->invalidate() #15 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle() #16 /var/www/clients/client1/web2/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle() #17 {main} {„uid“:„15ead6e“}
[2021-09-27T22:40:35.363810+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„1ad663d“}
[2021-09-27T22:40:35.369373+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„1ad663d“}
[2021-09-27T22:40:35.370156+02:00] core.ERROR: Enlight_Exception: Method „Shopware::Cache“ not found failure in /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php:154 Stack trace: #0 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Components/SoapApi.php(145): Shopware->__call() #1 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php(154): Shopware\SwagTrustedShopsExcellence\Components\SoapApi->checkCertificateTypeIfExcellence() #2 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/Handler/Default.php(90): Shopware\SwagTrustedShopsExcellence\Subscriber\Frontend->onCheckoutPostDispatch() #3 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Default->execute() #4 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Action.php(196): Enlight_Event_EventManager->notify() #5 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(461): Enlight_Controller_Action->dispatch() #6 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Front.php(225): Enlight_Controller_Dispatcher_Default->dispatch() #7 /var/www/clients/client1/web2/web/engine/Shopware/Kernel.php(192): Enlight_Controller_Front->dispatch() #8 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle() #9 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle() #10 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward() #11 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Shopware\Components\HttpCache\AppCache->forward() #12 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(283): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass() #13 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate() #14 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->invalidate() #15 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle() #16 /var/www/clients/client1/web2/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle() #17 {main} {„uid“:„1ad663d“}
[2021-09-27T22:40:51.969961+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„291c85b“}
[2021-09-27T22:40:51.975872+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„291c85b“}
[2021-09-27T22:40:51.976765+02:00] core.ERROR: Enlight_Exception: Method „Shopware::Cache“ not found failure in /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php:154 Stack trace: #0 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Components/SoapApi.php(145): Shopware->__call() #1 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php(154): Shopware\SwagTrustedShopsExcellence\Components\SoapApi->checkCertificateTypeIfExcellence() #2 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/Handler/Default.php(90): Shopware\SwagTrustedShopsExcellence\Subscriber\Frontend->onCheckoutPostDispatch() #3 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Default->execute() #4 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Action.php(196): Enlight_Event_EventManager->notify() #5 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(461): Enlight_Controller_Action->dispatch() #6 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Front.php(225): Enlight_Controller_Dispatcher_Default->dispatch() #7 /var/www/clients/client1/web2/web/engine/Shopware/Kernel.php(192): Enlight_Controller_Front->dispatch() #8 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle() #9 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle() #10 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward() #11 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Shopware\Components\HttpCache\AppCache->forward() #12 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(283): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass() #13 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate() #14 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->invalidate() #15 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle() #16 /var/www/clients/client1/web2/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle() #17 {main} {„uid“:„291c85b“}
[2021-09-27T22:41:33.890429+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„cb9cbae“}
[2021-09-27T22:41:33.899384+02:00] core.CRITICAL: Method „Shopware::Cache“ not found failure {„uid“:„cb9cbae“}
[2021-09-27T22:41:33.900041+02:00] core.ERROR: Enlight_Exception: Method „Shopware::Cache“ not found failure in /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php:154 Stack trace: #0 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Components/SoapApi.php(145): Shopware->__call() #1 /var/www/clients/client1/web2/web/engine/Shopware/Plugins/Community/Frontend/SwagTrustedShopsExcellence/Subscriber/Frontend.php(154): Shopware\SwagTrustedShopsExcellence\Components\SoapApi->checkCertificateTypeIfExcellence() #2 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/Handler/Default.php(90): Shopware\SwagTrustedShopsExcellence\Subscriber\Frontend->onCheckoutPostDispatch() #3 /var/www/clients/client1/web2/web/engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Default->execute() #4 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Action.php(196): Enlight_Event_EventManager->notify() #5 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(461): Enlight_Controller_Action->dispatch() #6 /var/www/clients/client1/web2/web/engine/Library/Enlight/Controller/Front.php(225): Enlight_Controller_Dispatcher_Default->dispatch() #7 /var/www/clients/client1/web2/web/engine/Shopware/Kernel.php(192): Enlight_Controller_Front->dispatch() #8 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle() #9 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(477): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle() #10 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward() #11 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(267): Shopware\Components\HttpCache\AppCache->forward() #12 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(283): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass() #13 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate() #14 /var/www/clients/client1/web2/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->invalidate() #15 /var/www/clients/client1/web2/web/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle() #16 /var/www/clients/client1/web2/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle() #17 {main} {„uid“:„cb9cbae“}
Wenn ich das Plugin deaktiviere funktioniert wieder alles. Ist das Plugin nicht kompatibel? Ich habe keine Warnung vorher erhalten.
kweb
