I have one major issue in my custom plugin. I developed the custom plugin in shopware version 6.4.* . The custom plugin working correctly in shopware version 6.4.* series. But the plugin is not working in shopware version 6.5.0.
So, I tried to fix the problem. But unfortunately it’s failed. The reason for issue is generated js file mismatch between shopware version 6.4 and 6.5.
I have attached the screenshot. please helps to troubleshooting the issue.
Note : In screenshot left side : 6.5.0 and right side : 6.4.20.2
Thanks for your reply. I hoped there will be a better solution but it seems its the only one. So after the update to 6.5 the plugin stop working in the frontend until the shopowner updated the plugin. Thats sad
