One ZIP for Shopware Store plugin with Settings/Extensions config – compatible with 6.4.x and 6.5.x?
Hi everyone,
I have a question about preparing a ZIP package for the Shopware Store.I’m building a plugin that has a custom configuration page under Settings > Extensions.
Is it possible to create one ZIP file that works for both Shopware 6.4.x and 6.5.x without having to rebuild the JS files for each version?
The JS part isn’t using anything too advanced or version-specific, but I know the admin panel structure changed a bit between 6.4 and 6.5, so I want to be sure.
Has anyone managed to make this work smoothly across versions? Any tips or insight into how Shopware Store handles this during review?
Thanks in advance!
My bad, I did not know of that way @EikeBrandtWarneke is referring, too. But I guess it is quite complicated.
Actually it is possible to ship one plugin version which supports Shopware 6.4 to 6.7 but its quite complicated and takes a lot of effort. You may have a look at the current Mollie plugin which is compatible from 6.4.5.0 up until 6.7.x.x
Kind regards
Dieses Thema wurde automatisch 30 Tage nach der letzten Antwort geschlossen. Es sind keine neuen Antworten mehr erlaubt.
