I’m just checking out shopware to see if its suitable for a project I’m working on. I’m running the latest dockware dev image that has version 6.5.1.0. I would like to check out the PWA storefront. I downloaded the extension and first snag was that there is no Settings->System->Plugins, but there is Extensions. So I tried uploading PWA there. However when trying to install I got the following error:
Failed Dependency
Required plugin/package "shopware/core ~6.4.0" does not match installed version == 6.5.1.0.
Does PWA not support 6.5 ? Is there a different installation procedure?
