Hallo Leute,
Hat jemand eine Idee wie ich das lösen kann ?
Unable to install, got message: An exception occurred while executing ‚SELECT t0.id AS id_1, t0.name AS name_2, t0.onclick AS onclick_3, t0.class AS class_4, t0.position AS position_5, t0.active AS active_6, t0.pluginID AS pluginID_7, t0.controller AS controller_8, t0.action AS action_9, t0.shortcut AS shortcut_10, t0.parent AS parent_11, t0.parent AS parent_12, t0.pluginID AS pluginID_13 FROM s_core_menu t0 ORDER BY LIMIT 1‘: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‚LIMIT 1‘ at line 1
