Problem bei Installation
Guten Abend,
ich versuche gerade Shopware zu installieren, habe die Dateien mittels GIT und Plesk kopiert. Die Systemvorraussetzungen sind allesamt grün, trotzdem bricht die Installation mit folgender Fehlermeldung ab:
Slim Application Error
Type: Doctrine\DBAL\DBALException
Message: An exception occurred while executing ‚SELECT s0_.id AS id_0, s0_.name AS name_1, s0_.label AS label_2, s0_.namespace AS namespace_3, s0_.source AS source_4, s0_.description AS description_5, s0_.active AS active_6, s0_.added AS added_7, s0_.installation_date AS installation_date_8, s0_.update_date AS update_date_9, s0_.refresh_date AS refresh_date_10, s0_.author AS author_11, s0_.copyright AS copyright_12, s0_.license AS license_13, s0_.version AS version_14, s0_.support AS support_15, s0_.changes AS changes_16, s0_.link AS link_17, s0_.update_version AS update_version_18, s0_.update_source AS update_source_19, s0_.capability_update AS capability_update_20, s0_.capability_install AS capability_install_21, s0_.capability_enable AS capability_enable_22, s0_.capability_secure_uninstall AS capability_secure_uninstall_23, s0_.translations AS translations_24 FROM s_core_plugins s0_ WHERE s0_.active = 1 AND s0_.installation_date IS NOT NULL‘: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‚s0_.translations‘ in ‚field list‘
File: /var/www/vhosts/racemob.de/httpdocs/vendor/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php
Line: 119
Trace
#0 /var/www/vhosts/racemob.de/httpdocs/vendor/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(836): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(PDOException), ‚SELECT s0_.id A…‘, Array)
#1 /var/www/vhosts/racemob.de/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Query/Exec/SingleSelectExecutor.php(50): Doctrine\DBAL\Connection->executeQuery(‚SELECT s0_.id A…‘, Array, Array, NULL)
#2 /var/www/vhosts/racemob.de/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/Query.php(321): Doctrine\ORM\Query\Exec\SingleSelectExecutor->execute(Object(Doctrine\DBAL\Connection), Array, Array)
#3 /var/www/vhosts/racemob.de/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(969): Doctrine\ORM\Query->_doExecute()
#4 /var/www/vhosts/racemob.de/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(924): Doctrine\ORM\AbstractQuery->executeIgnoreQueryCache(NULL, 1)
#5 /var/www/vhosts/racemob.de/httpdocs/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(727): Doctrine\ORM\AbstractQuery->execute(NULL, 1)
#6 /var/www/vhosts/racemob.de/httpdocs/engine/Shopware/Components/Theme/Util.php(191): Doctrine\ORM\AbstractQuery->getResult(1)
#7 /var/www/vhosts/racemob.de/httpdocs/engine/Shopware/Components/Theme/Installer.php(231): Shopware\Components\Theme\Util->getActivePlugins()
#8 /var/www/vhosts/racemob.de/httpdocs/engine/Shopware/Components/Theme/Installer.php(145): Shopware\Components\Theme\Installer->synchronizePluginThemes()
#9 /var/www/vhosts/racemob.de/httpdocs/engine/Shopware/Components/Theme/Installer.php(116): Shopware\Components\Theme\Installer->synchronizeThemes()
#10 /var/www/vhosts/racemob.de/httpdocs/recovery/install/src/Service/ThemeService.php(61): Shopware\Components\Theme\Installer->synchronize()
#11 /var/www/vhosts/racemob.de/httpdocs/recovery/install/src/app.php(440): Shopware\Recovery\Install\Service\ThemeService->activateResponsiveTheme()
#12 [internal function]: {closure}()
#13 /var/www/vhosts/racemob.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)
#14 /var/www/vhosts/racemob.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()
#15 /var/www/vhosts/racemob.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#16 /var/www/vhosts/racemob.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#17 /var/www/vhosts/racemob.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#18 /var/www/vhosts/racemob.de/httpdocs/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#19 /var/www/vhosts/racemob.de/httpdocs/recovery/install/index.php(74): Slim\Slim->run()
#20 {main}
Kann mir jedam erklären, wo der Fehler liegen könnte?
Vielen Dank für die Hilfe
was genau heißt in deinem Fall kopiert mit GIT?
Willst du generell Shopware installieren / produktiv nutzen? Dann bitte da immer nur auf die offiziellen Pakete zurückgreifen unter dem Punkt „Downloads“. Dort dann das Installationspaket herunterladen oder noch einfacher, den One-File-Installer. Der One-File-Installer holt automatisch immer das aktuelles Release, lädt es auf deinen Server, etnpackt es direkt und startet den Installer.
(http://community.shopware.com/Downloads_cat_448.html)
Das ist der schnellste und einfachste Weg für eine saubere Shopware Installation
Sebastian
vielen Dank für die schnelle Antwort,
hab den Installer noch einmal probiert, nun hat alles geklappt!
