Hallo! Wir versuchen gerade unseren neuen Shop einzurichten. Nun kommt jedoch wenn man sich als bestehender Kunde anmelden will folgende Fehlermeldung: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') IS NULL HAVING countArticles\>0 ORDER BY position, description' at line 10 in Vendor/Zend/library/Zend/Db/Statement/Pdo.php on line 234 Stack trace: #0 Vendor/Zend/library/Zend/Db/Statement.php(320): Zend\_Db\_Statement\_Pdo-\>\_execute(Array) #1 Vendor/Zend/library/Zend/Db/Adapter/Abstract.php(479): Zend\_Db\_Statement-\>execute(Array) #2 Vendor/Zend/library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend\_Db\_Adapter\_Abstract-\>query('????SELECT c.\*,...', Array) #3 Enlight/Components/Db/Adapter/Pdo/Mysql.php(50): Zend\_Db\_Adapter\_Pdo\_Abstract-\>query('????SELECT c.\*,...', Array) #4 Shopware/Plugins/Default/Frontend/AdvancedMenu/Bootstrap.php(154): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>query('????SELECT c.\*,...', Array) #5 Shopware/Plugins/Default/Frontend/AdvancedMenu/Bootstrap.php(100): Shopware\_Plugins\_Frontend\_AdvancedMenu\_Bootstrap-\>getCategoryTree('3', 2) #6 Shopware/Plugins/Default/Frontend/AdvancedMenu/Bootstrap.php(78): Shopware\_Plugins\_Frontend\_AdvancedMenu\_Bootstrap-\>getAdvancedMenu('3', '3', 2) #7 [internal function]: Shopware\_Plugins\_Frontend\_AdvancedMenu\_Bootstrap::onPostDispatch(Object(Enlight\_Event\_EventArgs)) #8 Enlight/Event/EventHandler.php(60): call\_user\_func('Shopware\_Plugin...', Object(Enlight\_Event\_EventArgs)) #9 Enlight/Event/EventManager.php(70): Enlight\_Event\_EventHandler-\>execute(Object(Enlight\_Event\_EventArgs)) #10 Enlight/Controller/Action.php(76): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Array) #11 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight\_Controller\_Action-\>dispatch('confirmAction') #12 Enlight/Controller/Front.php(99): Enlight\_Controller\_Dispatcher\_DispatcherDefault-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #13 Shopware/Bootstrap.php(33): Enlight\_Controller\_Front-\>dispatch() #14 Enlight/Application.php(86): Shopware\_Bootstrap-\>run() #15 shopware.php(6): Enlight\_Application-\>run() #16 {main} Woran kann das liegen? Grüße
