Hallo, bei uns tritt jetzt folgender Fehler auf: Ups! Ein Fehler ist aufgetreten! Die nachfolgenden Hinweise sollten Ihnen weiterhelfen. SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ’ 25.1260504202, ‘2012-09-13 10:37:41’, 0, ‘’, ‘’, ’ at line 12 in Vendor/Zend/library/Zend/Db/Adapter/Pdo/Abstract.php on line 280 Stack trace: #0 Enlight/Components/Adodb.php(83): Zend_Db_Adapter_Pdo_Abstract->exec(’???INSERT I…’) #1 engine/core/class/sBasket.php(2146): Enlight_Components_Adodb->Execute(’???INSERT I…’) #2 Shopware/Controllers/Frontend/Checkout.php(276): sBasket->sAddArticle(‘2001330’, ‘1’) #3 [internal function]: Shopware_Controllers_Frontend_Checkout->addArticleAction() #4 Shopware/Proxies/ShopwareControllersFrontendCheckoutProxy.php(6): call_user_func_array(Array, Array) #5 Shopware/Plugins/Community/Frontend/SwagBonusSystem/Bootstrap.php(627): Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy->excuteParent() #6 [internal function]: Shopware_Plugins_Frontend_SwagBonusSystem_Bootstrap::onAddArticle(Object(Enlight_Hook_HookArgs)) #7 Enlight/Hook/HookHandler.php(104): call_user_func(‘Shopware_Plugin…’, Object(Enlight_Hook_HookArgs)) #8 Enlight/Hook/HookManager.php(95): Enlight_Hook_HookHandler->execute(Object(Enlight_Hook_HookArgs)) #9 Shopware/Proxies/ShopwareControllersFrontendCheckoutProxy.php(22): Enlight_Hook_HookManager->executeHooks(Object(Enlight_Hook_HookArgs)) #10 Enlight/Controller/Action.php(70): Shopware_Proxies_ShopwareControllersFrontendCheckoutProxy->addArticleAction() #11 Enlight/Controller/Dispatcher/DispatcherDefault.php(329): Enlight_Controller_Action->dispatch(‘addArticleActio…’) #12 Enlight/Controller/Front.php(99): Enlight_Controller_Dispatcher_DispatcherDefault->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #13 Shopware/Bootstrap.php(33): Enlight_Controller_Front->dispatch() #14 Enlight/Application.php(86): Shopware_Bootstrap->run() #15 shopware.php(6): Enlight_Application->run() #16 {main} Entweder es wird im Browser angezeigt wie jeder Fehler auch oder es wird nur in Firebug angezeigt, während ein kleines weisses Kästchen in der Mitte des Bildschirms hängt und vorgibt etwas zu laden, was aber nicht passiert. Heute Update von Hosteurope auf php 3.5.16 Weiß jemand Rat? Gruß Saxosee
